Multiple source selection tracking for room?
Typical multi-display room; I need to track source selection for two displays separately. My mind is a blank slate on this one. Any suggestions?
integer Display_count=2; // number of displays you want to track.
DEFINE_VARIABLE
volatile integer Current_Source[Display_count]
// set or read these cells of the integer array to set/read the current source.
Current_Sourc[1] is the integer id for display one
Current_Sourc[2] is the integer id for display two
Oooooh... RMS...
that's the danger of browsing the forum the way I do. I didn't pay attention to which section the post was posted. Sorry about that. I thought the question was odd. But, it was just me being odd.
If you're using the AMX SDK, you'll need to create a tracking module for each display output. The best advice on the AMX SDK is to remember that they almost never take into account that there may be more than one of a thing. They just don't do arrays. Their solution is to simply burn up another huge chunk of resources to do the same simple task again.
The under-the-hood truth about the SDK is that it's basically converting everything down to a set of commands that get sent to and from RMS. The RMS commands are easier to understand (IMHO) than the SDK. The commands are all built within a framework that you can easily construct your own using arrays and so forth. It's actually pretty "programming bloat free" As I've said, I built my own RMS interface. It's one module and covers everything with no regard to how many devices you want to use, what features/monitoring/etc... per device with no regard to device type.
If you've ever worked with SQL databases before, I highly encourage you to ditch the SDK and roll your own interface. You'll spend most of your development time in the back 20 pages of the SDK's manual, not combing through the front 80.
I think in the short term I'll just cut functionality that the SDK can't handle, then in the longer term, the reality is that I'll never have time to write my own code and update systems. So whatever I do now, under time pressure, we're stuck with indefinitely.
I hate it when all the choices basically suck.
