FileTransfer2 - "only one instance" error
Has anyone been seeing this issue where FileTransfer2 throws this error every time you try to open it?: "Only one instance of the File Transfer 2 program is allowed".
I am getting this on two separate systems and have the same problem even if it's the first application that I try to open after a reboot...
Thanks!
    Which version of Windows are you running? (I can't believe I just typed that...)
  • tdewildtdewild Posts: 49
    Same here on Windows 10 Pro x64
    If you really want to send files at the same time, use FileTransfer 2 and NetLinx Studio 4.
    A free tip because it's almost weekend ;)
    If you need to do firmware update on a large DGX/DVX/DxLink system, use NetLinx Studio 4 and NetLinx Diagnostics at the same time to do the job, now it cost the halve of time.
  • pdabrowskipdabrowski Posts: 184
    I had the same just now but after killing the process and relaunching it came back.
    Windows 10 x64
