Cox Contour STB IR Control
bano
Despite my exhaustive and best efforts, I cannot control the new cox contour boxes via ir. Been coding almost 20 years so I've tried everything in my book. I own an Iris and put that through the paces but no go. Was able to acquire hex codes but they didn't work. Any help will be greatly appreciated. Thank you.
Aside from making sure that you're 100% positive that the emitter is good and that you're 100% positive that the AMX IR port is good, I'm out of ideas as well. I assume the cable box is good and that it works with the original remote.
Used the emitter/port on another device and it worked fine. The cable box does have the ability to do ir/rf simultaneously, and I can get it to work with it's own remote via ir. Thanks for the quick response Joe.
Tim
