Basic Volume Control, variable problem
So I'm trying to do a basic volume control with a bar graph but I get an error. This is what I have.
Define_Device
dvBiamp = 5001:4:0
Define_Constant
Volume_Level_Max = 0
Volume_Level_Min = -100
Define_Variable
Non_Volatile SInterger snBargraphVolume[3]
BUTTON_EVENT [dvTP,41] //Volume Up
PUSH:
IF (snBargraphVolume < Volume_Level_Max); // Limit how high we increment
SEND_STRING dvBiamp, "VolumeUp"
snBargraphVolume++; // Increase value by 1
BUTTON_EVENT [dvTP,42] //Volume Down
PUSH:
IF (snBargraphVolume > Volume_Level_Min); // Limit how low we increment
SEND_STRING dvBiamp, "VolumeDn"
snBargraphVolume --; // Decrease value by 1
I get an error that says "Operators "+", "-", "/" and "*" are only allowed for 1 dimensional arrays. All I want to do is add 1 to the variable snBargraphVolume
  • JasonSJasonS Posts: 229
    You defined snBargraphVolume as an array. Either define it as a single sinteger, or increment/decrement an element of the array, i.e. snBargraphVolume[1]++;
  • You're right. Thanks. I copied part of that from another program that worked and the reason for the array was because there were 3 different volume controls. I forgot why "[3]" was in there.
