Russound MCA-66 on RS-232 with RIO
Hi!
Trying to set-up a Russound multi-room audio controller with RS-232.
The issues is that Russound will not react to any commands on Serial connection, while they look correct and will not send any feedback.
However, MCA-66 does send data after reboot which looks like this:
These strings do look like the former RNET protocol, but I'm pretty sure the length is wrong.
Could that be a fault in Russound itself OR a problem with cabling?
Line 17 (16:44:26):: String From [5001:1:1]-[$F0$00$10u$00$00$7F$00$04$06$05$01$00$08$07$00$06$00$06$05$01$00$00$00$01$00$01$00$00D$F7$F0$00 u$00$00$7F$00$04$06$05$01$00$08$07$00$06$01$06$05$01$00$00$00$01$00$01$00$00U$F7] Line 18 (16:44:27):: String From [5001:1:1]-[$F0$00$10u$00$00$7F$00$04$06$05$01$00$08$07$00$06$00$06$05$01$00$00$00$01$00$01$00$00D$F7$F0$00 u$00$00$7F$00$04$06$05$01$00$08$07$00$06$01$06$05$01$00$00$00$01$00$01$00$00U$F7] Line 19 (16:44:29):: String From [5001:1:1]-[$F0$00$10u$00$00$7F$00$04$06$05$01$00$08$07$00$06$00$06$05$01$00$00$00$01$00$01$00$00D$F7$F0$00 u$00$00$7F$00$04$06$05$01$00$08$07$00$06$01$06$05$01$00$00$00$01$00$01$00$00U$F7$F0$00] Line 20 (16:44:29):: String From [5001:1:1]-[$10u$00$00$7F$00$04$06$05$01$00$08$07$00$06$00$06$05$01$00$00$00$01$00$01$00$00D$F7$F0$00 u$00$00$7F$00$04$06$05$01$00$08$07$00$06$01$06$05$01$00$00$00$01$00$01$00$00U$F7$F0}$00$7F] Line 21 (16:44:29):: String From [5001:1:1]-[$00$00$7F$05$02$01$00$02$01$00U$01Q$00$02$00$015$F7$F0$7F$00$00$00$00$7F$00$03$06$02$06$00$00$00$01$00$01$00$00$15$F7$F0$7F$00$00$00$00$7F$00$03$04$04$03$02$0B$01$00$00$01$00$01$00$00"] Line 22 (16:44:29):: String From [5001:1:1]-[$F7] Line 23 (16:44:29):: String From [5001:1:1]-[$F0}$00$7F$00$00$7F$05$02$01$00$02$01$00f$01$00$00$EB$03$01a$F7] Line 24 (16:44:39):: String From [5001:1:1]-[$F0}$00$7F$00$00$7F$05$02$01$00$02$01$00f$01$00$00$EC$03$01b$F7] Line 25 (16:45:39):: String From [5001:1:1]-[$F0}$00$7F$00$00$7F$05$02$01$00$02$01$00f$01$00$00$ED$03$01c$F7]
The issue was found - simple as $0D not being sent and Russound going mad...
AMX Level=(Level*51)/10
I have Massio keypads with their level knobs. The knob returns 0-255, while russound accepts 0-50. It works OK if I use a button_event on that knob, but with known rotation speed limits. I'd rather use a level_event for volume control.
okay.. I will do the algebra for you. that's
Device level = (AMX level * 10) / 51
Using the level is an okay thing to do but you do have to know and understand the behaviors and tolerances of the devices in play.
For example: the keypad might possibly generate many level_events from just one spin of the knob. The AMX processor is probably well able to handle so many events in such a short span of time. However, you might overrun the rs232 buffer if you try to send a whole series of send_string messages based upon the level_evnts that a single spin could generate.
In addition, the Russound might not like being banged on that much as well. (I find this to be the case most the time: the device needs a bit of a breather between messages.)
An easy way to deal with this is to either build a queue for your outgoing messages that will stack all the messages up but send them out at a nice controlled pace, or build a bit of logic that looks for bursts of level_events and just ignores the first ones and only sends out the last of the bunch. The end result for the user will be fairly unseen as it can all happen with millisecond or even 10th of a second delay. Mere humans won't be bothered by that.
I tend to queue all my rs232 stuff because I've already built the code to do it and don't need to re-write it. It works just fine for simple one-shot commands but saves a lot of heartache when things get chatty. The second method might be easier to write right in the level_event itself but I'm not a fan of one-shot code when avoidable. That's just me...
LEVEL_EVENT [dvKP1, 2] { IF (level.value % 5 = 0) { IF (kp1LVL <= level.value) { SEND_STRING dvMCA66, "'EVENT C[1].Z[3]!KeyPress VolumeUp', $0D" SEND_LEVEL dvKP1, 1, level.value kp1LVL = level.value } ELSE { SEND_STRING dvMCA66, "'EVENT C[1].Z[3]!KeyPress VolumeDown', $0D" SEND_LEVEL dvKP1, 1, level.value kp1LVL = level.value } } }just because I can not use a variable on volume level - SEND_STRING command converts any variable to HEX instead of ASCII. Any ideas how to TURN THIS CONVERSION OFF?This approach also makes for more universal code, so if you trade out the volume device at some point, you don't rewrite code, just update the table if needed.
If you want to send an ASCII representatation of some numeric value, you have to convert it. Something like:
of course I made up the command, don't know anything about the MCA66
But in the output log I see a string of for an occasion of 24 in the variable for example.
Will check the ITOA function right off.
EDIT: The ITOA works like a charm - specifically the function that was needed. THANK YOU
EDIT 2 : For other people who will ran in to the MCA66 - here's the simple code I am using. It controls the volume level pretty darn smooth
LEVEL_EVENT [dvKeypad, 2] { IF (level.value % 5 = 0) //we have 255 level on keypad and 50 levels on MCA66, check if they match { z3Vol = level.value / 5 //make a volume variable for MCA66 SEND_STRING dvMCA66, "'EVENT C[1].Z[3]!KeyPress Volume ', ITOA(z3Vol), $0D" //command to change volume. SEND_LEVEL dvKeypad, 1, level.value keyapd1LVL = level.value //save the level value last used in-case of desync, power outage, etc. } }This: needs to be this:
SEND_STRING dvMCA66 "'EVENT C[1].Z[3]!KeyPress Volume ', itoa(z1Vol), $0D"
if you wanted it to read "18" from your example.
