Change GMT offset
Dear All,
although I have read many topics about this, I have not come to a clear conclusion . I'm using the ASTRO_CLOCK to keep the sunrise/sunset times, but I need to manually change the GMT offset parameter from the code every 6 months for the sunrise/sunset values to be synchronized .
In my case the astro_clock(22.572563, 40.282520, 2.0, LDATE, sSunRise, sSunSet) works for summer time while the astro_clock(22.572563, 40.282520, 3.0, LDATE, sSunRise, sSunSet) for winter time. If I don't change the GMT offset ( from 2 to 3 and vice versa) , the sunrise/sunset values will be an hour onward or backward for 6 months period.
My question :
How can I get from code when daylight saving and standard time change ? If I have this information, I can make some piece of code to change the GMT offset value and pass it into the ASTRO_CLOCK function, without the need to be manually changed by me every 6 months.
For example :
if ( date = x )
nGMT = 2 //daylight_saving_time
if ( date = y )
nGMT = 3 //standard_time
astro_clock(22.572563, 40.282520,nGMT, LDATE, sSunRise, sSunSet)
George
My question :
For example :
if ( date = x )
if ( date = y )
George
PROGRAM_NAME='VAV_Date_&_Time' (***********************************************************) (* FILE_LAST_MODIFIED_ON: 03/29/2016 AT: 18:58:55 *) (***********************************************************) DEFINE_CONSTANT //DST <<<************************* CHANGE SETTING PER JOB *********************************>>> //Typically clocks are adjusted forward one hour near the start of spring and are adjusted backward in autumn.[1] //Starting in 2007, Daylight Saving Time (DTS) has been extended by one month. Therefore, the start date of DTS in the United States has been //changed to the 2nd Sunday in March and the end date of DTS has been changed to the 1st Sunday in November //If Daylight Savings Time is currently being observed (between spring and fall), set this item to "1". If Daylight Savings Time //is not currently being observed (between fall and spring) or is not observed in your geographic location, set this item to "0". //This item is used to correctly calculate the times for sunrise and sunset. INTEGER DST_OBSERVED = 1; //1 for yes and 0 for no INTEGER DST_OFFSET = 1; //number of hours time is offset INTEGER DST_BEGIN_MONTH = 3; //March (months 1-12 January to December) INTEGER DST_END_MONTH = 11; //November (months 1-12 January to December) INTEGER DST_BEGIN_DAY = 1; //Sunday (day of week 1-7 Sunday to Saturday) INTEGER DST_END_DAY = 1; //Sunday (day of week 1-7 Sunday to Saturday) INTEGER DST_BEGINDAY_OCCURANCE = 2; //Number of occurances of that day in that month (2nd Sunday) INTEGER DST_ENDDAY_OCCURANCE = 1; //Number of occurances of that day in that month (1st Sunday) CHAR DST_BEGIN_TIME[] = '02:00:00'; //Time change occurs CHAR DST_END_TIME[] = '02:00:00'; //Time change occurs DEFINE_CONSTANT //ASTRO_CLOCK LAT/LONG <<<************************* CHANGE SETTING PER JOB *********************************>>> INTEGER CLKMGR_DST = 1; //1 for ON and 0 for OFF INTEGER CLKMGR_DST_OFFSET_HR = 1; //1 for 1 hour INTEGER CLKMGR_DST_OFFSET_MIN = 0; //0 for 0 minutes INTEGER CLKMGR_DST_OFFSET_SEC = 0; //0 for 0 seconds INTEGER CLKMGR_RESYNC_PERIOD = 240; //in minutes 480 = 8 hours, choices: 5 min, 15 min, 2 hour, 4 hours & (8 hours?) //the web interface doesn't show an 8 hour option but the keyword example only shows //an hour hour example. So I choose the highest the web gui lists 4 hours/240 minutes. DOUBLE CLKMGR_LAT = -73.42; //Longitude - Longitude in Degrees.Fraction of Degrees. West longitudes must be negative. DOUBLE CLKMGR_LONG = 41.98; //Latitude - Latitude in Degrees.Fraction of Degrees. South latitudes must be negative DOUBLE CLKMGR_OFFSET_GMT_EST = -5.0; //HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as DOUBLE CLKMGR_OFFSET_GMT_EDT = -4.0; //HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as CHAR CLKMGR_TIME_ZONE[] = 'UTC-05:00'; //Input string must have the correct format: UTC[+|-]HH:MM CHAR CLKMGR_ACTIVESERVER[] = '132.163.4.101'; DEFINE_CONSTANT //TIME CONSTANTS Days of Week & Month of Year SUNDAY = 1; MONDAY = 2; TUESDAY = 3; WEDNESDAY = 4; THURSDAY = 5; FRIDAY = 6; SATURDAY = 7; JANUARY = 1; FEBRUARY = 2; MARCH = 3; APRIL = 4; MAY = 5; JUNE = 6; JULY = 7; AUGUST = 8; SEPTEMBER = 9; OCTOBER = 10; NOVEMBER = 11; DECEMBER = 12; FIRST = 1; SECOND = 2; THIRD = 3; FOURTH = 4; FIFTH = 5; EXPIRES_IN_SECONDS = 10; INTEGER NUM_SECONDS_MINUTE = 60; INTEGER NUM_SECONDS_30MIN = 1800; INTEGER NUM_SECONDS_HOUR = 3600; LONG NUM_SECONDS_DAY = 86400; INTEGER NUM_MINUTES_HOUR = 60; INTEGER NUM_MINUTES_DAY = 1440; CHAR DAY_OF_WEEK_ABREV[7][3] = {'SUN','MON','TUE','WED','THU','FRI','SAT'} CHAR DAY_OF_WEEK_FULL[7][9] = {'Sunday','Monday','Tuesday','Wednesday','Thursday','Friday','Saturday'} CHAR MONTH_OF_YR_ABREV[12][3] = {'Jan','Feb','Mar','Apr','May','Jun','Jul','Aug','Sep','Oct','Nov','Dec'}; CHAR MONTH_OF_YR_FULL[12][9] = {'January','February','March','April','May','June','July','August','September','October','November','December'}; CHAR DAYS_MONTHs[12] = {31 ,28 ,31 ,30 ,31 ,30 ,31 ,31 ,30 ,31 ,30 ,31}; CHAR DAYS_LEAPMONTHs[12] = {31 ,29 ,31 ,30 ,31 ,30 ,31 ,31 ,30 ,31 ,30 ,31}; DEFINE_CONSTANT //UI FEEDBACK EVENTS FB_TIME_TIME = 1; FB_TIME_SUNRISE = 2; FB_TIME_SUNSET = 3; FB_TIME_DST = 4; FB_TIME_HOLIDAY = 5; DEFINE_TYPE //TIME STUFF STRUCTURE _sMyTime { INTEGER nYear; INTEGER nMonth; INTEGER n24Hour; INTEGER n12Hour; INTEGER nMinute; INTEGER nSecond; INTEGER nDayOfMonth; INTEGER nDayOfWeek; INTEGER nDayOccurance[7]; LONG nTime_Seconds; LONG nTime_Minutes; CHAR c24Time[8]; CHAR c12Time[8]; INTEGER nWeekOfMonth; INTEGER nPlusDays; INTEGER nDaytime; INTEGER nTimePM_flag; CHAR cAMPM[2]; LONG nSunriseTime; LONG nSunSetTime; INTEGER nSunRiseTimeMinutes; INTEGER nSunSetTimeMinutes; CHAR cSunrise[10]; CHAR cSunset[10]; INTEGER nSunset24Hour; INTEGER nSunset12Hour; INTEGER nSunsetMinute; INTEGER nSunsetSecond; INTEGER nSunriseHour; INTEGER nSunriseMinute; INTEGER nSunriseSecond; CHAR cHoliday[24]; CHAR cDay[3]; CHAR cDate[8]; CHAR cWebCurDateTime[29]; CHAR cWebExpDateTime[29]; } DEFINE_TYPE //DST STRUCTURE _sMyDST { INTEGER nDST_Active; INTEGER nOffset; INTEGER nObserved; INTEGER nBEG_Month; INTEGER nEND_Month; INTEGER nBEG_Day; INTEGER nEND_Day; INTEGER nBEG_DAY_Occurance; INTEGER nEND_DAY_Occurance; } DEFINE_TYPE //_sGet_ClkMgr STRUCTURE _sGet_ClkMgr { INTEGER nReSyncPeriod; INTEGER nIs_DST_On; CHAR cTimeZone[9]; CHAR cDST_StartRule[128]; CHAR cDST_EndRule[128]; CLKMGR_TIMESERVER_STRUCT sActiveTimeServer; CLKMGR_TIMEOFFSET_STRUCT sOffset; CLKMGR_TIMESERVER_STRUCT sTimeServers[4]; } DEFINE_TYPE //CLKMGR_TIMEOFFSET_STRUCT FROM NETLINX.AXI FOR REFERNCE ONLY (* STRUCTURE CLKMGR_TIMEOFFSET_STRUCT { INTEGER HOURS; INTEGER MINUTES; INTEGER SECONDS; } *) DEFINE_VARIABLE //STRUCTURES PERSISTENT _sMyTime sMyTime; VOLATILE _sMyDST sMyDST; VOLATILE _sGet_ClkMgr sGet_ClkMgr;//just holds the get queries VOLATILE INTEGER nTimeWait_Force = 1; VOLATILE INTEGER nTime_DeBug = 1; DEFINE_VARIABLE //TIMELINE VOLATILE LONG nTL_TIME_RT[] = {250}; DEFINE_FUNCTION LONG fnConv_24HrTimeToSeconds(CHAR iTime[]) { RETURN ((((ATOI(REMOVE_STRING(iTime,"':'",1)) * 60) + ATOI(REMOVE_STRING(iTime,"':'",1))) * 60) + ATOI(iTime)); } DEFINE_FUNCTION CHAR[8] fnConv_SecondsTo24HrTime(LONG iTimeInSeconds) { RETURN "right_string("'0',ITOA(iTimeInSeconds / 3600)",2),':', right_string("'0',ITOA((iTimeInSeconds % 3600) / 60)",2),':', right_string("'0',ITOA((iTimeInSeconds % 3600) % 60)",2)"; } DEFINE_FUNCTION CHAR[30] fnDo_24hrTimeAddition(CHAR iLDate[],CHAR i24HourTime[],LONG iSecondsAdded) { STACK_VAR INTEGER nYear; //change to all stack_var's STACK_VAR INTEGER nMonth; STACK_VAR INTEGER nLeap; STACK_VAR CHAR c24HrTime[8]; STACK_VAR CHAR cNewDate[10]; STACK_VAR LONG nDay; STACK_VAR LONG nDaysOver; STACK_VAR LONG nSecondsRemain; STACK_VAR LONG nTotalTimeSeconds; nTotalTimeSeconds = fnConv_24HrTimeToSeconds(i24HourTime) + iSecondsAdded; nMonth = atoi("REMOVE_STRING(iLDATE,"'/'",1)"); nDay = atoi("REMOVE_STRING(iLDATE,"'/'",1)"); nYear = atoi("iLDATE"); if(nTotalTimeSeconds > NUM_SECONDS_DAY) { STACK_VAR INTEGER i; nDaysOver = nTotalTimeSeconds / NUM_SECONDS_DAY; nSecondsRemain = nTotalTimeSeconds % NUM_SECONDS_DAY; if(!(nYear % 4))//http://en.wikipedia.org/wiki/Leap_year { nLeap = 1; if(!(nYear % 100))//double check these rules?????? { if(nYear % 400) { nLeap = 0; } } } if(nLeap) { if((nDaysOver + nDay) > DAYS_LEAPMONTHs[nMonth]) { nDaysOver = nDaysOver - (DAYS_LEAPMONTHs[nMonth] - nDay); nMonth++; for(nMonth = nMonth; nDaysOver > DAYS_LEAPMONTHs[nMonth]; nMonth++) { nDaysOver = (nDaysOver - DAYS_LEAPMONTHs[nMonth]); if(nMonth == 12) { nMonth = 1; nYear ++; } } nDay = nDaysOver; } else { nDay = nDaysOver + nDay; } } else { if((nDaysOver + nDay) > DAYS_MONTHs[nMonth]) { nDaysOver = nDaysOver - (DAYS_MONTHs[nMonth] - nDay); nMonth++; for(nMonth = nMonth; nDaysOver > DAYS_MONTHs[nMonth]; nMonth++) { nDaysOver = (nDaysOver - DAYS_MONTHs[nMonth]); if(nMonth == 12) { nMonth = 1; nYear ++; } } nDay = nDaysOver; } else { nDay = nDaysOver + nDay; } } c24HrTime = fnConv_SecondsTo24HrTime(nSecondsRemain); } else { c24HrTime = fnConv_SecondsTo24HrTime(nTotalTimeSeconds); } cNewDate = "right_string("'0',ITOA(nMonth)",2),'/',right_string("'0',ITOA(nDay)",2),'/',right_string("'0',ITOA(nYear)",2)"; RETURN "DAY_OF_WEEK_ABREV[TYPE_CAST(DAY_OF_WEEK(cNewDate))],', ',itoa(nDay),' ',MONTH_OF_YR_ABREV[nMonth],' ',itoa(nYear),' ',c24HrTime"; } DEFINE_FUNCTION fnFB_Time(INTEGER iUI_Indx,INTEGER iEvent) //<< SET VT ADDRESS CHANNELS CHANGE SETTING PER JOB **********************>>> { SWITCH(iEvent) { CASE FB_TIME_TIME: { //panels can handle time on their own } CASE FB_TIME_SUNRISE: { fnFB_TimeSend_VT(iUI_Indx,1,"'Sunrise at ',itoa(sMyTime.nSunriseHour),':',itoa(sMyTime.nSunriseMinute),' AM'"); } CASE FB_TIME_SUNSET: { fnFB_TimeSend_VT(iUI_Indx,2,"'Sunset at ',itoa(sMyTime.nSunset12Hour),':',itoa(sMyTime.nSunsetMinute),' PM'"); } CASE FB_TIME_DST: { if(sMyDST.nDST_Active) { //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: IN EFFECT'"); } else { //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: NOT IN EFFECT'"); } } CASE FB_TIME_HOLIDAY: { fnFB_TimeSend_VT(iUI_Indx,4,"sMyTime.cHoliday"); } } } DEFINE_FUNCTION fnFB_TimeSend_VT(INTEGER iUI_Indx,INTEGER iCHAN,CHAR iStrMSG[500]) { STACK_VAR INTEGER n; STACK_VAR INTEGER nTPCount; STACK_VAR INTEGER nLoopStart; if(iUI_Indx) { nTPCount = iUI_Indx; nLoopStart = iUI_Indx; } else { nTPCount = NUM_UIs_IN_SYSTEM; nLoopStart = 1; } //fnTime_DeBug("'SEND_VT: ',iStrMSG,' :DEBUG <',itoa(__LINE__),'>'"); for(n = nLoopStart; n <= nTPCount; n++) { SWITCH(nUI_TypeArry[n]) { CASE UI_TYPE_G4: CASE UI_TYPE_R4: CASE UI_TYPE_MIO_DMS: (* no need for uni strings!!! { STACK_VAR WIDECHAR cSTRING1[500]; STACK_VAR CHAR cSTRING2[500]; cSTRING1 = WC_DECODE(iStrMSG,WC_FORMAT_UTF8,1); cSTRING2 = WC_ENCODE(cSTRING1,WC_FORMAT_TP,1); //fnTime_DeBug("'^UNI- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'"); SEND_COMMAND dvUI_Arry[n], "'^UNI-',itoa(iCHAN),',0,',cSTRING2"; } *) CASE UI_TYPE_G3: CASE UI_TYPE_iPHONE://uni not supported yet CASE UI_TYPE_iPAD: CASE UI_TYPE_iTOUCH: { //fnTime_DeBug("'^TXT- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'"); SEND_COMMAND dvUI_Arry[n], "'TEXT',itoa(iCHAN),'-',iStrMSG"; } CASE UI_TYPE_METKP: CASE UI_TYPE_UNKNOWN: CASE UI_TYPE_VIRTUAL: { //DO NOTHING } } } RETURN; } DEFINE_FUNCTION fnTime_DeBug(CHAR iStr[]) { if(nTime_DeBug) { STACK_VAR CHAR cCopyStr[1024]; STACK_VAR INTEGER nLineCount; cCopyStr = iStr; nLineCount ++; WHILE(length_string(cCopyStr) > 100) { SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',get_buffer_string(cCopyStr,100)"; nLineCount ++; } if(length_string(cCopyStr)) { SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',cCopyStr"; } } RETURN; } DEFINE_FUNCTION fnGet_DST_State() {//don't care about the hour of day it actually occurs! fnTime_DeBug("'fnCheckDST_Rule(): Checking DST State :DEBUG <',ITOA(__LINE__),'>'"); SELECT { ACTIVE(sMyTime.nMonth < DST_BEGIN_MONTH || sMyTime.nMonth > DST_END_MONTH): {//quick elimination sMyDST.nDST_Active = 0; } ACTIVE(sMyTime.nMonth > DST_BEGIN_MONTH && sMyTime.nMonth < DST_END_MONTH): {//quick elimination sMyDST.nDST_Active = 1; } ACTIVE(sMyTime.nMonth == DST_BEGIN_MONTH): { if(sMyTime.nDayOccurance[sMyDST.nBEG_Day] >= sMyDST.nBEG_DAY_Occurance) { sMyDST.nDST_Active = 1; } else { sMyDST.nDST_Active = 0; } } ACTIVE(sMyTime.nMonth == DST_END_MONTH): { if(sMyTime.nDayOccurance[sMyDST.nEND_Day] >= sMyDST.nEND_DAY_Occurance) { sMyDST.nDST_Active = 0; } else { sMyDST.nDST_Active = 1; } } ACTIVE(TRUE): { fnTime_DeBug("'fnCheckDST_Rule(): DST Check Error! :DEBUG <',ITOA(__LINE__),'>'"); RETURN; } } if(sMyDST.nDST_Active) { fnTime_DeBug("'fnCheckDST_Rule(): DST is Active! :DEBUG <',ITOA(__LINE__),'>'"); } else { fnTime_DeBug("'fnCheckDST_Rule(): DST is In-Active! :DEBUG <',ITOA(__LINE__),'>'"); } fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_DST); RETURN; } DEFINE_FUNCTION fnGet_AstroClock() { LOCAL_VAR SINTEGER nTimeMngr_Result; fnTime_DeBug("'fnAstro_Clock(): Running ArtoClock! :DEBUG <',ITOA(__LINE__),'>'"); sGet_ClkMgr.cTimeZone = CLKMGR_GET_TIMEZONE(); sGet_ClkMgr.nReSyncPeriod = CLKMGR_GET_RESYNC_PERIOD(); sGet_ClkMgr.nIs_DST_On = CLKMGR_IS_DAYLIGHTSAVINGS_ON();// this only return whether it's observed or not not if it's active, very stupid! sGet_ClkMgr.cDST_EndRule = CLKMGR_GET_END_DAYLIGHTSAVINGS_RULE(); sGet_ClkMgr.cDST_StartRule = CLKMGR_GET_START_DAYLIGHTSAVINGS_RULE(); CLKMGR_GET_TIMESERVERS(sGet_ClkMgr.sTimeServers); CLKMGR_GET_DAYLIGHTSAVINGS_OFFSET(sGet_ClkMgr.sOffset); CLKMGR_GET_ACTIVE_TIMESERVER(sGet_ClkMgr.sActiveTimeServer); if(sMyDST.nObserved) { fnGet_DST_State(); } //SINTEGER ASTRO_CLOCK(DOUBLE Longitude,DOUBLE Latitude,DOUBLE HoursFromGMT,CHAR[] Date,CHAR[] Sunrise,CHAR[] Sunset) if(sMyDST.nDST_Active)// { nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EDT,LDATE,sMyTime.cSunrise,sMyTime.cSunset); } else { nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EST,LDATE,sMyTime.cSunrise,sMyTime.cSunset); } fnTime_DeBug("'fnAstro_Clock(): Sunset Time = ',sMyTime.cSunset,' :DEBUG <',ITOA(__LINE__),'>'"); sMyTime.nSunset24Hour = atoi(left_string(sMyTime.cSunset,2)); sMyTime.nSunsetMinute = atoi(mid_string(sMyTime.cSunset,4,2)); sMyTime.nSunsetSecond = atoi(right_string(sMyTime.cSunset,2)); sMyTime.nSunsetTime = ((((sMyTime.nSunset24Hour * 60) + sMyTime.nSunsetMinute) * 60) + sMyTime.nSunsetSecond); sMyTime.nSunSetTimeMinutes = TYPE_CAST(sMyTime.nSunSetTime / 60); if(sMyTime.nSunset24Hour >= 12) { sMyTime.nSunset12Hour = sMyTime.nSunset24Hour - 12; } else//yeah, I know! { sMyTime.nSunset12Hour = sMyTime.nSunset24Hour; } fnTime_DeBug("'fnAstro_Clock(): Sunrise Time = ',sMyTime.cSunrise,' :DEBUG <',ITOA(__LINE__),'>'"); sMyTime.nSunriseHour = atoi(left_string(sMyTime.cSunrise,2)); sMyTime.nSunriseMinute = atoi(mid_string(sMyTime.cSunrise,4,2)); sMyTime.nSunriseSecond = atoi(right_string(sMyTime.cSunrise,2)); sMyTime.nSunriseTime = ((((sMyTime.nSunriseHour * 60) + sMyTime.nSunriseMinute) * 60) + sMyTime.nSunriseSecond); sMyTime.nSunRiseTimeMinutes = TYPE_CAST(sMyTime.nSunriseTime / 60); fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNRISE); fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNSET); } DEFINE_FUNCTION fnGet_DayOccurrences() { if(sMyTime.nDayOfWeek && sMyTime.nDayOfMonth) { STACK_VAR INTEGER i; STACK_VAR INTEGER nD_O_W; sMyTime.nWeekOfMonth = sMyTime.nDayOfMonth / 7; sMyTime.nPlusDays = sMyTime.nDayOfMonth % 7; for(i = 1; i <= 7; i ++)//first erase stored values { sMyTime.nDayOccurance[i] = 0; } nD_O_W = sMyTime.nDayOfWeek; sMyTime.nDayOccurance[nD_O_W] ++; for(i = sMyTime.nDayOfMonth; i > 1; i --) { if(nD_O_W > 1) { nD_O_W -- ; } else { nD_O_W = 7; } sMyTime.nDayOccurance[nD_O_W] ++; } fnTime_DeBug("'fnFindDayOccurences(): The First Day of the Month= ',DAY_OF_WEEK_ABREV[nD_O_W],' (',itoa(nD_O_W),') :DEBUG <',ITOA(__LINE__),'>'"); fnTime_DeBug("'fnFindDayOccurences(): Weeks= ',itoa(sMyTime.nWeekOfMonth),', Days= ',itoa(sMyTime.nPlusDays), ', Day= ',itoa((sMyTime.nWeekOfMonth * 7) + sMyTime.nPlusDays),' of ',MONTH_OF_YR_ABREV[sMyTime.nMonth],' :DEBUG <',ITOA(__LINE__),'>'"); } else { fnTime_DeBug("'fnFindDayOccurences(): Error! No Value in sMyTime.nDayOfWeek or sMyTime.nDayOfMonth :DEBUG <',ITOA(__LINE__),'>'"); } } DEFINE_FUNCTION fnGet_Holiday() { sMyTime.cHoliday = ''; SWITCH(sMyTime.nMonth) { CASE JANUARY: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 1): { sMyTime.cHoliday = 'New Years Day'; } ACTIVE(sMyTime.nDayOccurance[MONDAY] == THIRD && sMyTime.nDayOfWeek == MONDAY): { sMyTime.cHoliday = "'M.L.King',39,'s Birthday'"; } } } CASE FEBRUARY: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 2): { sMyTime.cHoliday = 'Ground Hog Day'; } ACTIVE(sMyTime.nDayOfMonth == 14): { sMyTime.cHoliday = "'Valentine',39,'s Day'"; } ACTIVE(sMyTime.nDayOfMonth == 22): { sMyTime.cHoliday = "'G. Washington',39,'s Birthday'"; } ACTIVE(sMyTime.nDayOccurance[MONDAY] == THIRD && sMyTime.nDayOfWeek == MONDAY): { sMyTime.cHoliday = "'President',39,'s Day'"; } } } CASE MARCH: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 9): { sMyTime.cHoliday = "'Employee Appreciation Day'"; } ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14): { sMyTime.cHoliday = "'Aniversary in ',itoa(14-sMyTime.nDayOfMonth),' days'"; } ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14): { STACK_VAR INTEGER nYears; nYears = sMyTime.nYear - 1984; SWITCH(nYears) { CASE 1:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'st Aniversary!'";} CASE 2:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'nd Aniversary!'";} CASE 3:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'rd Aniversary!'";} DEFAULT: { sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'th Aniversary!'"; } } } ACTIVE(sMyTime.nDayOfMonth == 17): { sMyTime.cHoliday = "'ST Patrick',39,'s Day'"; } } //EASTER? } CASE APRIL: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 1): { sMyTime.cHoliday = "'April Fool',39,'s Day'"; } ACTIVE(sMyTime.nDayOfMonth == 14): { sMyTime.cHoliday = "'Valentine',39,'s Day'"; } ACTIVE(sMyTime.nDayOccurance[MONDAY] == THIRD && sMyTime.nDayOfWeek == MONDAY): { sMyTime.cHoliday = "'Patriot',39,'s Day'"; } } } CASE MAY: { SELECT { ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth < 5): { sMyTime.cHoliday = "'Jill''s birthday in ',itoa(5-sMyTime.nDayOfMonth),' days'"; } ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14): { sMyTime.cHoliday = "'Jill''s birthday!'"; } ACTIVE(sMyTime.nDayOccurance[SUNDAY] == SECOND && sMyTime.nDayOfWeek == SUNDAY): { sMyTime.cHoliday = "'Mother''s Day'"; } ACTIVE(sMyTime.nDayOccurance[SATURDAY] == THIRD && sMyTime.nDayOfWeek == SATURDAY): { sMyTime.cHoliday = "'Armed Forces Day'"; } ACTIVE(sMyTime.nDayOccurance[MONDAY] == FOURTH && sMyTime.nDayOfMonth > 24 && sMyTime.nDayOfWeek == MONDAY): { sMyTime.cHoliday = 'Memorial Day'; } ACTIVE(sMyTime.nDayOccurance[MONDAY] == FIFTH && sMyTime.nDayOfWeek == MONDAY): { sMyTime.cHoliday = 'Memorial Day'; } } } CASE JUNE: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 14): { sMyTime.cHoliday = "'Flag Day'"; } ACTIVE(sMyTime.nDayOfMonth == 21): { sMyTime.cHoliday = "'Summer Solstice'"; } ACTIVE(sMyTime.nDayOccurance[SUNDAY] == THIRD && sMyTime.nDayOfWeek == SUNDAY): { sMyTime.cHoliday = "'Father',39,'s Day'"; } } } CASE JULY: { if(sMyTime.nDayOfMonth == 4) { sMyTime.cHoliday = 'Independence Day'; } } CASE AUGUST: { if(sMyTime.nDayOccurance[SUNDAY] == FIRST && sMyTime.nDayOfWeek == SUNDAY) { sMyTime.cHoliday = "'Friendship Day'"; } } CASE SEPTEMBER: { if(sMyTime.nDayOccurance[MONDAY] == FIRST && sMyTime.nDayOfWeek == MONDAY) { sMyTime.cHoliday = 'Labor Day'; } } CASE OCTOBER: { if(sMyTime.nDayOfMonth == 31) { sMyTime.cHoliday = 'Halloween'; } } CASE NOVEMBER: { SELECT { ACTIVE(sMyTime.nDayOfMonth == 1): { sMyTime.cHoliday = "'All Saint',39,'s Day'"; } ACTIVE(sMyTime.nDayOfMonth == 11): { sMyTime.cHoliday = "'Veteran',39,'s Day'"; } ACTIVE(sMyTime.nDayOccurance[THURSDAY] == FOURTH && sMyTime.nDayOfWeek == THURSDAY): { sMyTime.cHoliday = 'Thanksgiving Day'; } } } CASE DECEMBER: { SELECT { ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth <= 23): { sMyTime.cHoliday = "ITOA(25 - sMyTime.nDayOfMonth),' days to Christmas'"; } (* ACTIVE(sMyTime.nDayOfMonth == 21): { sMyTime.cHoliday = 'Winter Solstice'; } *) ACTIVE(sMyTime.nDayOfMonth == 24): { sMyTime.cHoliday = 'Christmas Eve'; } ACTIVE(sMyTime.nDayOfMonth == 25): { sMyTime.cHoliday = 'Christmas Day'; } ACTIVE(sMyTime.nDayOfMonth == 31): { sMyTime.cHoliday = "'New Year',39,'s Eve'"; } } } } if(length_string(sMyTime.cHoliday)) { sMyTime.cHoliday = "'"',sMyTime.cHoliday,'"'"; fnTime_DeBug("'fnFindHolidays(): Today is ',sMyTime.cHoliday,' :DEBUG <',ITOA(__LINE__),'>'"); } else { fnTime_DeBug("'fnFindHolidays(): Today is not a "supported" holiday! :DEBUG <',ITOA(__LINE__),'>'"); } fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_HOLIDAY); RETURN; } DEFINE_FUNCTION fnGet_WebDATE_TIME() { sMyTime.cWebCurDateTime = "fnDo_24hrTimeAddition(LDate,TIME,0),' EST'"; sMyTime.cWebExpDateTime = "fnDo_24hrTimeAddition(LDate,TIME,EXPIRES_IN_SECONDS),' EST'"; RETURN; } DEFINE_FUNCTION fnRun_SunRise_n_Set(INTEGER iDaytime) { //SWITCH(iDaytime) // { // CASE 0:{} //night // CASE 1:{} //day // } fnMain_SunRise_n_Set(iDaytime); } DEFINE_FUNCTION fnRun_D_O_W_Events(INTEGER iDayOfWeek) //<<************** CHANGE SETTING PER JOB **********************************>>> { STACK_VAR INTEGER nCopyDOW; nCopyDOW = iDayOfWeek; //SELECT ACTIVE or SWITCH CASE to do something } DEFINE_FUNCTION fnRun_D_O_M_Events(INTEGER iDayOfMonth) //<<************** CHANGE SETTING PER JOB **********************************>>> {//uncomment call in fnUpdate_Time() STACK_VAR INTEGER nCopyDOM; nCopyDOM = iDayOfMonth; //SELECT ACTIVE or SWITCH CASE to do something } DEFINE_FUNCTION fnRun_DailyEvents() //<<************** CHANGE SETTING PER JOB **********************************>>> { //fnDailyEmailTest(); fnGet_Holiday(); fnGet_AstroClock(); //SELECT ACTIVE or SWITCH CASE to do something fnMain_EveryDay(); } DEFINE_FUNCTION fnRun_HourEvents(INTEGER iHour) //<<************** CHANGE SETTING PER JOB **********************************>>> { STACK_VAR INTEGER nCopyHour; nCopyHour = iHour; fnMain_EveryHour(nCopyHour); //SELECT ACTIVE or SWITCH CASE to do something } DEFINE_FUNCTION fnRun_MinuteEvents(INTEGER iMinute) //<<************** CHANGE SETTING PER JOB **********************************>>> { STACK_VAR INTEGER nCopyMinute; nCopyMinute = iMinute; fnMain_EveryMinute(nCopyMinute); } DEFINE_FUNCTION fnRun_SecondEvents(INTEGER iSecond) //<<************** CHANGE SETTING PER JOB **********************************>>> { STACK_VAR INTEGER nCopySecond; nCopySecond = iSecond; SELECT//add as needed { ACTIVE(sMyTime.n24Hour == 23): { if(sMyTime.nMinute == 59) { if(nCopySecond == 59) {//used for log entry SEND_STRING 0,"'TIME-[ ',TIME,' ]. End day and begin a new!'"; } } } } fnGet_WebDATE_TIME(); fnMain_EverySecond(nCopySecond); } DEFINE_FUNCTION fnRun_StartUpCode() { LOCAL_VAR CLKMGR_TIMEOFFSET_STRUCT sMyCLKMGR_TIMEOFFSET; fnTime_DeBug("'fnRunStartUpCode(): Run Start Up! :DEBUG <',ITOA(__LINE__),'>'"); nTimeWait_Force = 1; sMyDST.nObserved = DST_OBSERVED; if(sMyDST.nObserved) { sMyDST.nOffset = DST_OFFSET; sMyDST.nBEG_Month = DST_BEGIN_MONTH; sMyDST.nEND_Month = DST_END_MONTH; sMyDST.nBEG_Day = DST_BEGIN_DAY; sMyDST.nEND_Day = DST_END_DAY; sMyDST.nBEG_DAY_Occurance = DST_BEGINDAY_OCCURANCE; sMyDST.nEND_DAY_Occurance = DST_ENDDAY_OCCURANCE; } WAIT 300//3000 { fnTime_DeBug("'fnRunStartUpCode(): Run Start Up Wait items! :DEBUG <',ITOA(__LINE__),'>'"); CLKMGR_SET_CLK_SOURCE(CLKMGR_MODE_NETWORK); // or CLKMGR_MODE_STANDALONE CLKMGR_SET_ACTIVE_TIMESERVER (CLKMGR_ACTIVESERVER); CLKMGR_SET_TIMEZONE(CLKMGR_TIME_ZONE); CLKMGR_SET_DAYLIGHTSAVINGS_MODE(TRUE);//moved to DST function CLKMGR_SET_START_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_BEGINDAY_OCCURANCE),',',itoa(DST_BEGIN_DAY),',',itoa(DST_BEGIN_MONTH),',',DST_BEGIN_TIME" ); CLKMGR_SET_END_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_ENDDAY_OCCURANCE),',',itoa(DST_END_DAY),',',itoa(DST_END_MONTH),',',DST_END_TIME" ); CLKMGR_SET_RESYNC_PERIOD(CLKMGR_RESYNC_PERIOD); sMyCLKMGR_TIMEOFFSET.HOURS = CLKMGR_DST_OFFSET_HR; sMyCLKMGR_TIMEOFFSET.MINUTES = CLKMGR_DST_OFFSET_MIN; sMyCLKMGR_TIMEOFFSET.SECONDS = CLKMGR_DST_OFFSET_SEC; CLKMGR_SET_DAYLIGHTSAVINGS_OFFSET(sMyCLKMGR_TIMEOFFSET); nTimeWait_Force = 2; fnUpdate_Time(); } if(!TIMELINE_ACTIVE(TL_TIME)) { TIMELINE_CREATE(TL_TIME,nTL_TIME_RT,1,timeline_absolute,timeline_repeat); } } DEFINE_FUNCTION fnUpdate_Time() { if(sMyTime.nSecond != TYPE_CAST(TIME_TO_SECOND(TIME)) || nTimeWait_Force) { sMyTime.nSecond = TYPE_CAST(TIME_TO_SECOND(TIME)); sMyTime.c24Time = TIME; if(sMyTime.nMinute != TYPE_CAST(TIME_TO_MINUTE(TIME)) || nTimeWait_Force) { sMyTime.nMinute = TYPE_CAST(TIME_TO_MINUTE(TIME)); //only 1 minute resolution for sunrise/set, could check every second but why, not that critical..... if(sMyTime.nTime_Seconds >= sMyTime.nSunriseTime && sMyTime.nTime_Seconds < sMyTime.nSunsetTime) { if(!sMyTime.nDaytime) { sMyTime.nDaytime = 1; fnRun_SunRise_n_Set(sMyTime.nDaytime); } } else { if(sMyTime.nDaytime) { sMyTime.nDaytime = 0; fnRun_SunRise_n_Set(sMyTime.nDaytime); } } if(sMyTime.n24Hour != TYPE_CAST(TIME_TO_HOUR(TIME)) || nTimeWait_Force) { sMyTime.n24Hour = TYPE_CAST(TIME_TO_HOUR(TIME)); if(sMyTime.n24Hour >= 12) { sMyTime.cAMPM = 'PM'; sMyTime.nTimePM_flag = 1; if(sMyTime.n24Hour > 12) { sMyTime.n12Hour = sMyTime.n24Hour - 12; } else { sMyTime.n12Hour = sMyTime.n24Hour; } } else { sMyTime.cAMPM = 'AM'; sMyTime.nTimePM_flag = 0; sMyTime.n12Hour = sMyTime.n24Hour; } sMyTime.c12Time = "itoa(sMyTime.n12Hour),':',RIGHT_STRING("'0',itoa(sMyTime.nMinute)",2),':',RIGHT_STRING("'0',itoa(sMyTime.nSecond)",2)"; if(sMyTime.nDayOfMonth != TYPE_CAST(DATE_TO_DAY(LDATE)) || nTimeWait_Force) { sMyTime.nDayOfMonth = TYPE_CAST(DATE_TO_DAY(LDATE)); sMyTime.nDayOfWeek = TYPE_CAST(DAY_OF_WEEK(LDATE)); if(sMyTime.nMonth != TYPE_CAST(DATE_TO_MONTH(LDATE)))//no force here. would erase stored values. { sMyTime.nMonth = TYPE_CAST(DATE_TO_MONTH(LDATE)); if(sMyTime.nYear != TYPE_CAST(DATE_TO_YEAR(LDATE))) { sMyTime.nYear = TYPE_CAST(DATE_TO_YEAR(LDATE)); } } if(sMyTime.cDay != Day || nTimeWait_Force) { sMyTime.cDay = Day; if (sMyTime.cDate != Date) { sMyTime.cDate = Date; } } fnGet_DayOccurrences(); fnRun_D_O_W_Events(sMyTime.nDayOfWeek); fnRun_D_O_M_Events(sMyTime.nDayOfMonth); fnRun_DailyEvents(); } fnRun_HourEvents(sMyTime.n24Hour); } else { sMyTime.c12Time = "itoa(sMyTime.n12Hour),':',RIGHT_STRING("'0',itoa(sMyTime.nMinute)",2),':',RIGHT_STRING("'0',itoa(sMyTime.nSecond)",2)"; } sMyTime.nTime_Minutes = ((sMyTime.n24Hour * 60) + sMyTime.nMinute); fnRun_MinuteEvents(sMyTime.nMinute); } else { sMyTime.c12Time = "itoa(sMyTime.n12Hour),':',RIGHT_STRING("'0',itoa(sMyTime.nMinute)",2),':',RIGHT_STRING("'0',itoa(sMyTime.nSecond)",2)"; } sMyTime.nTime_Seconds = ((((sMyTime.n24Hour * 60) + sMyTime.nMinute) * 60) + sMyTime.nSecond); fnRun_SecondEvents(sMyTime.nSecond); fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_TIME); //IF ANYTHING NEEDS TIME UPDATES } nTimeWait_Force = 0; } DEFINE_START //RUN START UP CODE fnRun_StartUpCode(); DEFINE_EVENT //TIMELINE_EVENT [TL_TIME] TIMELINE_EVENT [TL_TIME]//EVERY 250ms { fnUpdate_Time(); fnMain_250ms_Clock();//put any other timing events in the main in this function } DEFINE_PROGRAM //CALL fnUpdate_Time() if you don't have a timeline elsewhere to call it every second (* WAIT 10 { fnUpdate_Time(); } *) if(!TIMELINE_ACTIVE(TL_TIME)) { TIMELINE_CREATE(TL_TIME,nTL_TIME_RT,1,timeline_absolute,timeline_repeat); }
