Digest Access Authentication
vmail
Hi, I would like to web scape some data from a web page that uses digest access authentication.
I've captured this from Charles
telnet 192.168.1.11 80
GET /cgi-bin/minerStatus.cgi HTTP/1.1
Authorization: Digest username="root", realm="antMiner Configuration", nonce="e9e1achanged7", uri="/cgi-bin/minerStatus.cgi", response="b47changed342a", qop=auth, nc=00000001, cnonce="a3changed0"
This is nothing like basic authentication, how do I go about implementing this in either AMX or Telnet?
Even though the OP is about a year old I'll answer since I had to deal with this recently. Digest authentication essentially hashes (using MD5) several pieces of login information several times that makes decoding this information very difficult. I couldn't find any netlinx libraries that offered the functionality of MD5 hashing (which, by itself, is not a secure way of hashing sensitive information) but you can create your own function based on this pseudocode. https://en.wikipedia.org/wiki/MD5#Pseudocode
The process requires you to first send a simple request for the desired resource on the server and the response will be 401 (Unauthorized) along with a few pieces of information that you'll need to authenticate as seen in this example.
The pieces of information needed to finish authentication are as follows:
username: sent as "plain text"
realm: sent by the server in the first response
nonce: hash generated by the server and sent in the first response
uri: the resource you are requesting from the server (without the protocol and host)
qop: sent by the server in the first response. Depending on the value given from the server, you may need to hash different pieces of information together
nc: 16 bit counter padded with 0's. Depending on the server, you may have to increment this. In my case I could always send 00000001 and there was never a problem
cnonce: a random 4 Byte hex provided by the client device
response: this is the MD5 hex that is calculated based on what the value of the qop field is, sent by the server
opaque: a hash string sent by the server in the first response. In my case the server never sent this so I omitted it in consecutive requests
I had to develop a module that would connect to a server for a REST Web API. If I got the 401 response code I would go through the authentication process and save the necessary values if I needed to continue sending requests to that server.
Wikipedia was extremely helpful in developing the module as well as this collection of libraries (especially the includes for http and uri):
https://en.wikipedia.org/wiki/Digest_access_authentication
https://github.com/AMXAUNZ/amx-util-library
This is why this forum matters.
Howdy,
am having some difficulty implementing the amx-util-library
to initiate a GET request to a device (brightSign)
that requires Digest Authentication
(just trying to reboot it via an NX-1200)
have done a lot of digging but am still at a loss.
below is a rough breakdown of the programming:
PROGRAM_NAME = “blah”
include ‘http’
DEFINE_DEVICE
dvNX1200 = 5001:1:1
dvIO = 5001:22:1
dvIPServerTCP = 0:30:1
dvTstBSign = 0:500:1
DEFINE_CONSTANT
username = ‘admin’
password = ‘admin’
method = HTTP_METHOD_GET
requestUri = ‘/action.html?reboot=Reboot’
DEFINE_VARIABLE
char httpResponseBuffer[2048]
define_function connectTstBSign()
ip_client_open (500,’192.168.117.199’,80,IP_TCP)
DEFINE_START
create_buffer dvIPServerTCP, httpResponseBuffer
DEFINE_EVENT
DATA_EVENT [dvNX1200]
ONLINE:
IP_SERVER_OPEN(30,81,IP_TCP)
wait 30 connectTstBSign()
BUTTON_EVENT[dvIO,1]
PUSH:
send_string dvTstBSign, httpRequestToString(request);
DATA_EVENT[dvIPServerTCP]
STRING:
stack_var HttpResponse response
DEFINE_PROGRAM
wait 10 connectTstBSign()
and then in the http.axi
per the instructions/example
near line 955 was added:
HttpRequest request;
request.method = HTTP_METHOD_GET
request.requestUri = ‘/action.html?reboot=Reboot’
request.version = 1.1
httpSetHeader(request.headers, HTTP_HEADER_HOST, ‘192.168.117.199’);
httpSetHeader(request.headers, HTTP_HEADER__FIELD_AUTHORIZATION, httpDigestAuthentication());
when trying to compile
a syntax error is thrown at line 957
as well as a couple of warnings:
@todo: implement httpParseRequest method
@todo: implement httpGetHeaderName method
no idea what am doing wrong
halp plz!
cheers,
pie
There is another thread around which I responded to, I was using a Dahua Intercom which needed Digest and I pasted my prog into that
look at this thread. Hope it helps
https://proforums.harman.com/amx/discussion/comment/196982#Comment_196982
