Sorry my bad english, but CTG-KNX/IP from Comm-Tec is not stable!
With this gateway, we have many problems with network connections.
After a network interrupt, module does not correct reconnect, or hangs in Inti-State, sometimes its need a full controller-restart.
So i write my own little module wich communicate with KNXnet/IP Tunnelling Protocol.
Its works fine, and i can when needed free extend this module.
This gateway is cheaper than Comm-Tec-Gateway and does not need 220V power! You can also up to 5 network-connections at same time to this gatway! (NX-1200, ETS5, etc, etc, etc)
You need only ETS5 for configure the IP-Address & physical address.
ETS5 application is also available as demo by Maximum of 5 KNX devices per project.
I am using an Arcus-EDS KNX-GW-IP-2TE now, and the module written by Donald.Peter works fine with this gateway.
This module doesn't need ETS5 for configuration, it has a handy web interface.
I used the Commtec gateway in more then 50 projects. All the gateways are still working well and stable. But it's not available anymore.
OK, now I tested the brandnew Serial and IP Gateways from the german AMX distributer. Here is the link: https://audiopro.de/de/30362.html
the serial gateway can handle up to 1000 KNX addresses and the IP version can handle 3000 addresses. In my actual project I control 1950 addresses and everything works fine and stable.
There are some more intersting features:
it's possible to import the complete address table, exported bei ETS software
it's possible to manage 3000 addresses from the AMX side OR 1000 addresses from the KNX side.
it's possible to add addresses at runtime for testing
I'm happy with this gateway...
The NetLinx coding i have translated from C# by follow source:
https://github.com/lifeemotions/knx.net/tree/master/src/KNXLib
For more information, the full protocoll specification you can download from:
https://my.knx.org/en/shop/knx-specifications
This Specifications are free, (buy for 0$), you need only create a account on https://www.knx.org/
For gateway we use the Interface IPS/S 3.1.1 from ABB.
http://www.knx-gebaeudesysteme.de/sto_g/Deutsch/Oesterreich_Schweiz/ABB_ibus_KNX/_HTML/product_2CDG110177R0011.htm
In attachment you can find my module
Good luck
KnxNet is really, really good work, Donald.Peter!
See https://www.arcus-eds.de/system.html
Thank you Donald.Peter, you saved me weeks of coding.
Hi Donald.Peter,
is knx multicast address (224.0.23.12) supported in your module?
Thomas
We have had good experiences with Weinzierl KNX BAOS modules:
https://www.weinzierl.de/index.php/en/all-knx/knx-devices-en
The BAOS protocol for them is pretty well documented:
https://www.weinzierl.de/images/download/development/830/KnxBAOS_Protocol_v2.pdf
