Quick Quiz
Here is a little pop quiz I'm throwing out because
A. I'm feeling nostalgic
B. I'm trying a help out some of the newer coders think like the compiler, and I am choosing this format to accomplish it
Given this bit of code:
What would be the result of the following:
I invite everyone to play along, and I will post an explanation in a day or two.
P.S.
I forgot that I am operating under the assumption that stack_vars are initialized to 0 when created.
define_constant
NUMBER_OF_TOUCHPANELS = 10;
define_variable
integer nOverviewMode[NUMBER_OF_TOUCHPANELS] = {1,2,3,1,2,3,4,1,4,1};
integer nAdminMode[NUMBER_OF_TOUCHPANELS] = {0,1,0,0,0,0,0,0,0,0,0}
define_function integer getAdminMode(integer nTpIndex){
return nAdminMode[nTpIndex];
define_function integer getOverviewMode(integer nTpIndex){
stack_var integer nResult;
if(nTpIndex >0 and nTpIndex <= NUMBER_OF_TOUCHPANELS)
if(getAdminMode(nTpIndex))
nResult = nOverviewMode[nTpIndex];
else {
debug("'Invalid Touch panel index pointer in getOverviewMode function'",DEBUG_WARNING);
nResult = 99;
return nResult;
send_string 0,"'Overview Mode: ',itoa(getOverviewMode(1),' - ', itoa(getOverviewMode(2),' - ',itoa(getOverviewMode(13)";
P.S.
Failed to load the poll.
