Home AMX RPM Forum
Why can't I locate a particular source or output device in RPM?
RPM is designed to accommodate only the most common AV devices in typical conference rooms and classrooms. If you are unable to locate a device within RPM, it is most likely an uncommon or older device that is currently not supported in RPM.
