Home AMX RPM Forum
Does RPM support the iPad or other tablets?
RPM uses flash to generate the web pages. The RPM configuration can be done on any device or tablet that supports flash or by using an APP that allows flash on an IOS device. RPM does not natively support TPControl, however someone with TPD4 expertise could convert an MVP-9000i touch panel to use on an iPad or other tablet. The panel file will have to be loaded manually to the tablet.
