SVSI Native NetLinx Device Monitor Module
Because "sharing is caring" and currently you can't directly register a native Netlinx SVSi device ...
Should support any encoder or decoder - set up to support more device types if needed
Fully populates info page from device_info. Note that a dynamic virtual device is being referenced as the registering device.
Option to set custom name and description through the proxy command ( eg. send_command vdvRMS,'@-RMS-Asset-Name,')
Metadata:
1. IP Address as hyperlink
2. NetLinx D:P:S
Parameters:
1. Stream #
2. Audio Stream # (Decoders)
3. Host Play
4. Power Consumption
5. Online
Methods:
1. Reboot
2. Stream #
3. Audio Follow Video or Audio Stream # (Decoders)
4. Passthru
https://dropbox.com/s/in4ht8g9ykqak0r/RMS%20SVSi%20NetLinx%20Device%20Monitor.zip?dl=0
