Camera control
I am looking to connect 1 camera to 4 different SX-80s in a single A/V rack. My problem seems to be how to control the 1 camera with 4 different codecs. The HDMI seems to be no problem but the control function is my problem. Is there a way or a switcher that would allow the camera to connect to all 4 SX-80s at the same time so that when you switch to a new secure VTC call the system that you are on can control the camera.
Even if you need to use control from the codec, you could use any netlinx master to port the serial commands from the 4 codecs to one camera
> @JasonS said:
> Do you have to have the codecs controlling the camera, could the control system control the camera?
That is an option but the concern becomes proper isolation between codecs on secure and unsecure networks. This is a bit of a touchy subject and it is really dependent on the networks involved and the local security officer's approval. You do not want to violate any security policies as it makes things very difficult for your customer and affects wether they are allowed to use their system.
Ugh - Yeah this is why I have no desire to do anything requiring clearance. Sounds like a royal pain. I know that a lot of Netlinx Controllers are JTIC certified, but I don't really understand what that does or means. Don't people use one control system for rooms with secure/unsecure devices regularly?
Periods Processing. Pain. In. The. Ass. Factory reset the codec, reboot the codec, switch the black box (fiber tx/rx, power,etc) from one clearance to the other (which usually reboots the codec again because power to the codec goes through it), set the new registration server info on the codec and reboot again. If you know how long a Cisco C60 takes to reboot, you know that takes foreeeeeever. We added an extra "ARE YOU REALLY SURE?" because of how long it takes.
