NX-1200 and Netlinx
Hi Dears
I have NX-1200 in control system and i need to monitoring or supervise this controller.
I.e when any push any inputs from I/o port in need to log file contain the strings performed due to this push.
thanks.
  • From NetLinx Keyword help:
    File Operations Example: Writing to a File
    The following example code demonstrates writing to a file (typical usage):
    DEFINE_FUNCTION appendToFile (CHAR cFileName[],CHAR cLogString[])
    STACK_VAR SLONG slFileHandle // stores the tag that represents the file (or and error code)
    LOCAL_VAR SLONG slResult // stores the number of bytes written (or an error code)
    slFileHandle = FILE_OPEN(cFileName,FILE_RW_APPEND) // OPEN OLD FILE (OR CREATE NEW ONE)
    IF(slFileHandle>0) // A POSITIVE NUMBER IS RETURNED IF SUCCESSFUL
         slResult = FILE_WRITE_LINE(slFileHandle,cLogString,LENGTH_STRING(cLogString)) // WRITE THE NEW
        INFO
          FILE_CLOSE(slFileHandle)   // CLOSE THE LOG FILE
      ELSE
         SEND_STRING 0,"'FILE OPEN ERROR:',ITOA(slFileHandle)" // IF THE LOG FILE COULD NOT BE CREATED
    Which would be called like this:
    appendToFile(‘log.txt’,’Something happened…’)
    when an entry to this file needed to be written.
    Use the FILE_RW_APPEND constant for the IOFlag to append new data to the file.
