Help with NX-3200
Hay all, I have not touched AMX for a long while and I need a bit o'help.
I have a NX3200 that has 5 vaddio ccu's pluged into serial ports 1-5. The display only shows ports 1, 4, and 7 active with good TX/RX. . The result only Camera 2 (CCU2 on Port 4) is actually able to be called up. Now when I swap cables from CCU1 to 2 - the problem follows, and now only CCU1 shows up. I need help getting into game again...
Best Answer
Answers
