D:P:S addressing in different contexts
Say I define my device as
dvTPMBR = 10201
and I have the following event....the event works fine.
BUTTON_EVENT[dvTPMBR:2:0,1] {
PUSH: {
send_command dvTPMBR:2:0, "'^TXT-1,1&2,',TIME";
But then I separately have a structure with a DEV component
structure _sTPInfo {
dev dTP
If I have an array of these _sTPInfo structures, I can't address a specific port, like I could with the BUTTON_EVENT. The following code results in an error: C10512: Cannot convert type [DEV] to [INTEGER]
//inside a function that takes _sTPInfo sTPInfo[] as an argument
DEV dTP
char cTPIndex
dTP = sTPInfo[cTPIndex].dTP:3:0
Any ideas? It seems inconsistent to me, but this is the first time I've goofed with this. There must be a way to address various ports on a dev w/in an array of structures...
-Bill
dvTPMBR = 10201
PUSH: {
dev dTP
DEV dTP
char cTPIndex
-Bill
--D
Edit: You could also change the last line to:
dTP = sTPInfo[cTPIndex].dTP.device:3:0
which should work also (only returning the device element of the DEV)
If a panel, for example, is defined as
dvPanel = 10001: 1:0
...then you use
dvPanel.NUMBER = 10001
dvPanel.PORT = 1
dvPanel.SYSTEM = <whatever your system number is, since the 0 in the defnition is a shortcut for the current system).
I use these all the time in modules to report a device in SEND_STRING 0 statements for debugging so I can differentiate between different instances. There is a debug.axi file on the AMX site somewhere that also wraps them into nice little DEV to string functions.
