Russound ST2 Dual AM/FM Tuner
I am using a russ dual AM/FM Tuner. When i use the module, using either the AMX interface and comm or my interface and code and just using the comm module I get feedback in the data.text/buffer for both tuner 1 and 2 when I send commands to vdvTuner1, but when i send commands to vdvTuner2 I only get a response on data.text/buffer for tuner 2.
This plays hell in my variable text windows for tuner 2 when someone in another room makes changes to tuner 1.
What am I doing wrong? I called and spoke with tech support and they said they sent it to the "module department" but i have not heard back from them.
Your only other choice is to ignore the data that's coming from the module and write your own parser for the data coming back from the unit.
- Chip
That said, I've used the Russound module myself, and don't recall having that particular problem. Make sure you didn't mix up the reference in what they call nSourceNumbers[], and make sure you used two different virtual device addresses, and not two ports on the same virtual.
If you can make certain it really is a module flaw, you might have to ditch the feedback in the module and process the output of the tuner yourself. It's a pain, but the Russound is pretty well documented, it's an available option.
The module documentation for implementing the ST2 Dual Tuner reads like this:
DEFINE_DEVICE dv_ST2_PORT = 5001:1:0 // device port to tuner vdvTUNER1 = 33001:1:0 // virtual tuners (two modules per ST2 tuner) vdvTUNER2 = 33002:1:0 dvTP1 = 10001:1:0 // tp DEFINE_VARIABLE vdvTUNER_ARRAY[] = {vdvTUNER1, vdvTUNER2} // device array for two tuners nSource_Numbers[] = {1,2} // source address settings DEFINE_FUNCTION DEFINE_MODULE 'Russound_ST2_Comm' ST2_Comm_1 (vdvTuner_ARRAY,dv_ST2_PORT,nSource_Numbers)This describes a setup where you just have the dual tuner connected to the master on an rs232 port.
My question is, if you have a Russound 6.6 CAV with ARNet, and the ST2 is on the ARNet, the CAV can communicate with the Tuners without the Tuners needed a seperate RS232 port... so how do we declare the ST2's module in this situation?
I'm planning on giving Russound a call but if anyone has done this and knows what to do, please post. Thanks in advance.
I dont think it works that way..i think you have to go separate... If you fund out different, please post
