WebControl Problem
Hello All,
If i want to access my G4 panel though WebControl but I don't want to go through the regular WebControl Page, What is the Url I should write in the address bar?
Lets say the Netlinx master's IP is 192.168.1.1 and my G4 panel is at 192.168.1.2, I tried the following but with no success:
http://192.168.1.1 Javascript: showPanel('192.168.1.2','5900','192.168.1.2')
I need this because my costumer wants me to build him a website with a button named AMX that will access directly the named panel?
Thanks for the help
Ronen
Thanks for the help
Ronen
Is the link for access from within your clients private LAN? If so, try this:
http:// 192.168.1.1/G4WebControl.asp?ip=192.168.1.2&port=5900
Thanks for your quick response. The costumer wants access from the intranet as well from the internet.
I tried your solution and it works great. Will it also work from the internet?
P.S.
I already added to my code in the Define_Start:
SEND_COMMAND 0:1:0,'G4WC "SALON",80.179.11.80,5900,1'
Which is the external ip address.
You have to setup the router to pass PORT 5900 to the panel ip (192.138.1.2), then you can connect using http://80.179.11.80:5900
Hope this helps!
Thanks for all the answers guys,
works great ^^b
