NI3000 Duet Firmware - Dead HTTP Server
Hi, I have upgraded to the latest DUET firmware, my http server is now dead (see attached screenshot). I am not using any duet modules and have set the duet memory to 4Mb as per a few posts I have seen.
Any idea where I need to look for this?
  • Strange effect.... (that 4 MB Duet mem issue was posted by me).
    - If you do a "show mem" (w/o "") in Terminal, what memory sizes would you get?
    - Will the webserver work if you disable the runmode (Dipswitch 1 on the back to ON, reboot)?
    - What browser do you use?
    Regards,
  • hodeyphodeyp Posts: 104
    Hi Marc,
    Your last question was the most important, I was accessing via my mac using safari. I have just used a PC with IE and all looks ok.
    Is the netlinx web interface ie only?
  • hodeyp wrote:
    Hi Marc,
    Working on M$ Systems only....
    In general, I prefer Opera, but Opera is not supporting XML and SXL based pages (like the Duet webserver uses) :( It works fine with IE and Firefox.
    strange, I thought safari supported those. Firefox it is then!!
