Always PHASE ERROR
Hello, i use RADIA lighting system (rdd-dm6), and when i send PROlink strings to it, i always get 'PHASE ERROR' message, how to fix it?
P.S. Btw, lighting system seems to work OK.
  • It may appear to be working okay, but if you're using two AC feeds coming in to the module, (not bridging a single feed across all 6 channels) I believe this message is trying to tell you that the second one is out of phase with the first...
    - Chip
