Home AMX Technical Discussion
Panel to panel intercom....
Hey all. I know there are topics on here for panel to panel intercom but I still can’t get it working. Wondering if there is a problem with the kitchen panel mic. Here’s what I got.
Kitchen Panel (MXT-200XL-PANi) @ 192.168.1.220
Master Bath Panel (MSD-1001i) @ 192.168.1.210
When I call on either panel, I can talk into the master bath panel and you can hear the audio through the kitchen panel just fine. But when you talk into the kitchen panel, you can not here the audio in the master bath panel.
Here’s my code for intercom:
BUTTON_EVENT [dvTPKITCHEN_MAIN,60] // Call Master Bath
PUSH:
SEND_COMMAND dvTPKITCHEN_MAIN, "'^ICS-192.168.1.210,9002,9000,2'"
SEND_COMMAND dvTPKITCHEN_MAIN,"'^ICM-TALK'"
    SEND_COMMAND dvTP_BATH, "'^ICS-192.168.1.220,9000,9002,2'"
    SEND_COMMAND dvTP_BATH,"'^ICM-TALK'"
BUTTON_EVENT [dvTPKITCHEN_MAIN,61] // End Call Master Bath
PUSH:
SEND_COMMAND dvTPKITCHEN_MAIN, "'^ICE'"
SEND_COMMAND dvTP_BATH, "'^ICE'"
BUTTON_EVENT [dvTP_BATH,60] // Call Kitchen
PUSH:
SEND_COMMAND dvTP_BATH, "'^ICS-192.168.1.220,9002,9000,2'"
    SEND_COMMAND dvTPKITCHEN_MAIN, "'^ICS-192.168.1.210,9000,9002,2'"
BUTTON_EVENT [dvTP_BATH,61] // End Call Kitchen
PUSH:
Any ideas would be great. Yes, the mic is not muted in the kitchen panel and volumes are up.
    Reverse the panels IP addresses and try again. Does the fail remain with the same panel, implying it is physically bound and not programming?
  • Thanks for the ideas John. Turns out, after I download any graphics to the panels I must reboot both the panels and then the intercom function works. Not really sure what that's about. Firmware is up-to-date on both panels.
