LEVEL_EVENT on 2 Dimensional Array possible?
Is this possible? I'm currently getting a syntax error on the LEVEL_EVENT [myArray,1]
Will i need to make this LEVEL_EVENT[myArray[1],1]? Is there a better way?
DEFINE_DEVICE
dvTP1=10001:1:0
dvTP2=10002:1:0
DEFINE_VARIABLE
volatile dev myArray[2][3]
volatile integer lvlSlider[2] = {1,2}
volatile integer x
volatile integer port = 0
DEFINE_START
for(x=1;x<=2;x++)
    for(y=1;y<=3;y++)
        port++;
        myArray[x].number = 33001
        myArray[x].port = port
        myArray[x].system = 0
REBUILD_EVENT()
DEFINE_EVENT
    stack_var integer tp
    stack_var integer dv
    tp = get_last(myArray)
    dv = get_last(myArray[tp])
    send_level dvTP[tp],lvlSlider[dv],level.value
</code>DEFINE_DEVICE
dvTP1=10001:1:0
dvTP2=10002:1:0
DEFINE_VARIABLE
volatile integer x
DEFINE_START
for(x=1;x<=2;x++)
    for(y=1;y<=3;y++)
        port++;
REBUILD_EVENT()
DEFINE_EVENT
  • LEVEL_EVENT[myArray[x],1] is the only option
  • sentry07sentry07 Posts: 77
    The device in any _EVENT block can't be an array. You can, however, define more than one _EVENT header for a block of code.
    LEVEL_EVENT [myArray[1],1]
    LEVEL_EVENT [myArray[2],1]
    LEVEL_EVENT [myArray[3],1]
  • danportugaldanportugal Posts: 14
    Thanks gents.
