Event for multi-dimension device array
Hello everyone,
suppose the below code :
DEFINE_DEVICE
dvTP_1 = 10001:1:0;
dvTP_2 = 10001:2:0;
dvTP_3 = 10001:3:0;
dvTP_4 = 10001:4:0;
dvTP_5 = 10001:5:0;
dviPad_1 = 11001:1:0;
dviPad_2 = 11001:2:0;
dviPad_3 = 11001:3:0;
dviPad_4 = 11001:4:0;
dviPad_5 = 11001:5:0;
DEFINE_CONSTANT
    dev dvTP_LVL[ ][ ] =
                    { dvTP_1  , dvTP_2  , dvTP_3  , dvTP_4  , dvTP_5   },
                    { dviPad_1, dviPad_2, dviPad_3, dviPad_4, dviPad_5 }
        integer BTN_VOL_UP   = 24;
    integer BTN_VOL_DN   = 25;
            integer MODERO_PANEL = 1;
    integer IPAD_PANEL          = 2;
DEFINE_EVENT
button_event[dvTP_LVL[MODERO_PANEL],BTN_VOL_UP] //volume up from modero
push:
to[button.input]; //set button feedback
button_event[dvTP_LVL[IPAD_PANEL],BTN_VOL_UP] //volume up from iPad
push:
The above is a part of my code where any panel port represents an audio matrix output.
I'm afraid that if I had more panels ( ex. 10 panels ), I should make 10 x button events like the above ones.
Of course this is very hard ( not scalable at all ).
But if I had a simple dimension array like :
   dev dvTP_LVL[ ] =  { dvTP_1  , dvTP_2  , dvTP_3  , dvTP_4  , dvTP_5   }; //only the modero panel
everything seems very simple...
button_event[dvTP_LVL,BTN_VOL_UP] //volume up only from the modero panel
push:
What about if I have multi dimension device array ?
Is there a way to make only one button event for all panels at once ?
George
  • Stack the events maybe:
    button_event[dvTP_LVL[IPAD_PANEL],BTN_VOL_UP] //volume up from iPad{
    push:
