Set a variable from a list?
emdx71emdx71 Posts: 51
edited July 2020 in NetLinx Studio
Hi,
Trying to set a variable to tell the system if it has a DSP or not, based on a variable learned from the dsp itself when the system boots if its attached, so in simple terms if either a '64' or a '128' is returned from the device, has_dsp will = 1, however this is getting set as '1' regardless if there is something being returned or not. I assume i'm just not using the right operator
right now I'm using this under an online event for the dvMASTER device:
IF (DSP_TYPE = '"64'" || "'128'")
HAS_DSP=1
should the || be an ^^ for an xor
or am i going about this the wrong way?
  • richardhermanrichardherman Posts: 407
    edited July 2020
    I assume you meant:
    if (dsp_type == '64' or dsp_type == '128')
        has_dsp = 1
    ('64' or '128') wil always evaluate to true.
    Now it's another thing how, when the master comes online, it will know about anything returned from that device?
  • emdx71emdx71 Posts: 51
    @richardherman said:
    I assume you meant:
        has_dsp = 1
    Thank you sir. This worked as expected. I have a function defined to poll the dsp to get basic info from it, so as long as its on the correct port once a dsp is "detected" it sets everything into motion
