Recursive subscription function question.
Hello, Im a new programmer and I recently inherited a system with an NX4200.
I found this function handling the feedback polling of the audio DSP. It appears to be calling itself over and over again. Is this dangerous for the processor?
define_call 'DSP feedback registration'
if(length_string(cDSP_subscriptions[nDSP_param_polled]))
wait 10
if(VolumeCurrent[nDSP_param_polled])
SEND_LEVEL dvTP_Main,Volume_BTN_LVL_UP[nDSP_param_polled],VolumeCurrent[nDSP_param_polled]
send_string dvBiamp,"cDSP_subscriptions[nDSP_param_polled]"
nDSP_param_polled = nDSP_param_polled + 1
else
if(nDSP_param_polled < 101)
Thank you!
  • Looks like a call that was inherited from way back in the ancient 1990's Axcess programming days. Think it only runs 100 times at pop iterating over itself 1/second - must be called repeatedly from somewhere else in code.
    Better (read modern, efficient, portable, scalable, maintainable... ) way would probably be through a timeline.
    DEFINE_VARIABLE
    volatile long lDspPolling[] = {250}; // 1/4 second interval - muy rapido!
    DEFINE_EVENT
    someevent[someventTrigger]
      timeline_create(DSPFeedbackRegistration, lDspPolling, length_array(lDspPolling), TIMELINE_ABSOLUTE, TIMELINE_REPEAT);
    timeline_event[DSPFeedbackRegistration]
      local_var volatile integer iPolledParameter;
      iPolledParameter++;
      if(iPolledParameter > 100) // Max 100 parameters?
        timeline_kill(timeline.id);
      if(length_string(cDSP_subscriptions[iPolledParameter ]))
        if(VolumeCurrent[iPolledParameter ])
          SEND_LEVEL dvTP_Main, Volume_BTN_LVL_UP[iPolledParameter ], VolumeCurrent[iPolledParameter ]
        send_string dvBiamp, cDSP_subscriptions[iPolledParameter ]
