Zee Vee IR codes
Hey does anybody have a valid IR file for a ZeeVee Setop box (the sync) I've got a project and cant find one.
    The Global Cache Control Tower is a huge free access database of IR files. I just checked and the ZEEVEE Sync is one they have. Go get it....
    https://irdb.globalcache.com/
  • JohnMichnrJohnMichnr Posts: 279
    Thanks - I have 3 different hex codes. 2 that almost work, 1 is untested, and the global cache is a 4th one to try. I registered there but I'm not verified yet so I can't download a complete set, and the individual codec max out at like 12.
    I've sent you a pm with the full set. Note that the GC format is as seen below; the hex you want starts in the middle after the "," with the 4-digit codes. Paste them into IREDIT and save. The first part are codes that the CG devices use instead of the HEX, if you are using their products.
    Example:
    "STOP","sendir,1:1,1,38000,1,69,342,171,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,1533,342,85,21,3663","0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 0015 0015 0015 0015 003F 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 05FD 0156 0055 0015 0E4F",,
    Thanks - I got that and I'm trying the codes. I have 4 different hex codes for this box, from 4 different locations and none of them are the same. Right now I'm just building up an IR file with a bunch of them so I can see which one works.
