Multi-room setup with stand-alone operation
Hi all,
Very new to all of this and I've been given a task by my boss, so the situation is a configurable office space that can be separated to 3 rooms, the following must be possible:
rooms 1,2 and 3 operating simultaneously as separate meeting rooms running MS teams video calls
rooms 1+2, 2+3 or 1+3 operating together on one call
all rooms 1,2 and 3 running together as one call
can anyone advise me on a really basic level what sort of equipment they would use? and also if you would have a master controller in each room?
Couple of videos discussing a way to code this in NetLinx.
https://use.vg/m7XESm
Depending on what else is going on (number of user interfaces, displays, RMS, etc,...) a single master may work.
Nothing here that's outside the realm of NetLinx control possibilities. Audit the I/O and wiring requirements then select a master deployment model that best fits the findings. Possibly SVSi NAV and/or the new Precis family of product could be applied for the video "joining" requirement.
https://linksharing.samsungcloud.com/wl2ODEKHNaiq
The points you have mentioned should work perfectly my only question is, could the vibe system be configured to use multiple vibes for one meeting, (I.e. use the camera feed from two or more vibes in the same device feed via a codec etc?)
