AMX has an integration with MTR (Microsoft Teams Room application)?
Hello!
Do you know if AMX has an integration with MTR (Microsoft Teams Room application) to integrate AV Room control into it? Something like the "Extron Control for Microsoft Teams Rooms" capability.
I particularly need to control the room facilities with the touch panel of the MS Teams Native video conferencing equipment (Yealink, Logitech, Poly, etc.)
Answers
    There is no MTR integration at this time. Extron essentially adds a button to the MTR screen that triggers a page flip over to an HTML5 GUI that is hosted on their external controller. AMX can host an HTML5 panel on the controller today - the trick is getting that pageflip button onto the MTR screen. Do you have the documentation for adding the button to MTR?
  • DamianDamian Posts: 5
    edited December 2021
    Hi Chris, I don't have any document to add the button to MTR, it would be very helpful if you can provide it to me!
    Thanks in advance
    Damian, it is my understanding that each MTR hardware manufacturer partner controls their specific build of MTR and this is where the button is implemented. I do not have this document.
  • Hi Damian, I have now sendt an request to Yealink for the API-command sheet for the A30-Teams device. So I will post the answer her, if the anwer is good enough. The module on InConcert lacks the most important functions.
    Cheers
  • nicolaunicolau Posts: 49
    I am look for more information with regard to this video, that says about integration with AMX and MTR systems controlled by Yealink MTouch II Controller:
    https://www.youtube.com/watch?v=OtKC7mzmydw
    Can someone give more detailed information?
  • Keep your eye on the Developer Resources page for updates
    https://developer.amx.com/#!/main
    I couldn't find anything there searching for "Yealink". Could you help?
    Not released yet - waiting on Yealink official firmware release
  • Not shown in the new releases page yet but has been published and available for download.
    https://developer.amx.com/#!/searchresult?Manufacturer=Yealink
    Note that there will be a revised module published by the end of this week with a new jar, example JSON files and documentation.
    The NetLinx programming side is fairly straightforward - same a as touch panel with regards to buttons events, channel feedback and levels. Customization of the control page (JSON file) and setting up client Authentication and Authorization are a couple of the issues that need to be thoroughly understood from the documentation ( there are 3 guides covering different aspects of the solution in the AXW package).
