Home AMX Technical Discussion
IREdit supported by Windows10 version 21H1
Dear All,
I'm not sure if this is the problem but after the latest win10 update to version 21H1, the IREdit does not open/run and the below message appears:
Error
Error getting data. Received the following error message
Unknown error occurred
The above error is killed only from the Task Manager "End Task"
Has anyone of you faced this problem ?
George
    edited September 2021
    I'm running 21H1 and IREDIT "runs" as well as ever. Specifically, no change I can see from the sorta-nearly-stable-ish I'm used to since leaving WIN7. Fragile, but it does open. For serious editing, I run a virtual machine with WINXP.
  • OK John, what do you suggest ? In my case it doesn't "run" in no way.
    Should I uninstall and reinstall it ?
    Can't hurt to try, right? Install as ADMINISTRATOR, and follow through the compatibility mode dialogs.
  • banobano Posts: 175
    Use windows 10 pro 64. Installed IR edit in xp mode June 2020. Worked fine until December 2020. Hung up in the startup screen. Tried to reinstall with the help of tech support. Here was the solution:
    "There is hope... Consensus is that if you uninstall IREdit, then use the Registry Editor and delete the IREdit entry under HKEY_CURRENT_USER\SOFTWARE\AMX Corp.\
    This will erase all the settings, which will be replaced by the Installer. This worked for me to get rid of my "can't read data" warning, so hopefully will work for your problem as well."
