SVSI and Dante
 satyrux
satyrux
            Hello I allow myself to post here because I have the following question, have you succeeded in making work on a switch cisco (sg350 ..) on the same vlan the SVSI and the Dante ?? I tried several methods found on the internet but nothing works, each time I no longer have access to my Dante. The solution I found is to make a 2nd Vlan this way it works, but the problem is that I can no longer control the devices on my Vlan Dante (Micro Shure MXA910, ...) will one have a lead ?? Thanks in advance
Answers
SVSI and Dante can exist on the same VLAN. The attached document describes connecting BSS and SVSI AES67 audio which is Dante and SVSI on the same VLAN.
Hello, thank you for your quick response, if I understand correctly I configure my switch for the svsi (igmp activation, querier, ...) I add the 3 addresses 224.0.0.230/231/232 and I do not configure anything specific for Dante ?? Sorry for these questions
