Laptops with com ports
Matt Bradley
Are there any laptops out there these days that still have com ports, or has everyone gone straight to USB? I need to get a new laptop, but don't want the hassle of a USB to serial convertor (I hear nothing but bad about them). Surely there are still modern laptops with serial ports?
I ordered the card from Quatech directly off of their website (www.quatech.com).
Good luck.
Sheldon Samuels
IPS Resources LLC
- Chip
Chip, I'll check out the Dell's. I was thinking they were one of the manufacturers that did away with the com ports, but I could be wrong.
http://www.qualitycables.com/Category.cfm?catid=468&AZX=
and have had absolutely no problem with it.
I'm guessing that a lot of the similar cards come out of the same factory and get rebranded by different resellers.
Harold
It also happens that Dell didn't keep the Inpiron 9100 on the market for very long at all. Not sure why but maybe they knew something that they haven't made public.
For every good idea, there is always a trade-off. Take it for what its worth.
Sheldon Samuels
IPS Resources LLC
Kevin D.
Vince
The Keyspan adaptor works with Studio and all other AMX apps. without a problem. The reason is true Microsoft signed drivers for XP. I found it for $35.00 at buy.com with free shipping. http://www.buy.com/prod/Keyspan_High_Speed_USB_Serial_Adapter_Replaces_The_USA_19QW/q/loc/101/10357749.html
Same here, a Dell Latitude D810, I got this laptop about 6 months ago. Works just great, and the screen is just wonderful.
Wouldn't be nice if AMX put a USB port on everything and did away with the 9pin. Then all out troubles would be resolved. Oh and new ones created. <grin>.
Another thing I found when using a USB adapter is to check that the power for it is not controlled by Windows (look in device manager under each USB root hub for the power management tab.) this caught me when I recently replaced my laptop and had no end of trouble when in the middle of a job.
for the record i use a generic USB serial adapter. it has problems with IRIS, but that's about it.
but i just wanted to point out that if you can setup a netlinx controller without ever bothering with a serial port.
by default, the controller will do DHCP. so if you plug the controller into a network that you know (your office) and let it get assigned a network IP you are close to controlling it already.
after connecting the controller to a DHCP network, run a program like Scanport (try http://www.dataset.fr/eng/scanport.html)
Set it to scan for port 1319, and to scan the entire IP range of your network. (optionally, turn off 'Use PING', don't really need it). within a minute of two, the IP address assigned to your controller (and any netlinx controllers) should be displayed.
once you have that number, well, you know what to do from there.
The dell inspiron 600m or latitude 600m (essentially the same machine) have a single DB9 com port....this was the primarly reason I got the machine. It has held up well for me....
Rich
Okay, I don't have bad eyesight, but running at that res is just TOO small for me. I had to suck up the "fuzziness" that one gets running at non-native resolutions, but I've gotten quite used to 1280x800.
- Chip
Wow - I'm a patient person, but waiting for that procedure would drive me nuts. I jack in a 232 cable and manually set IP info on masters almost without thinking about it.
- Chip
Bill
yeah, you're right it can be quick and simple to setup with RS232. it's a suggestion, and the time may balance out, where the scan time ~= the serial setup time.
and if you don't have a serial port/cable, it is also a solution to finding the controller. and your network installation is tested in the process of course, if there is no DHCP or a fault in the network, then sorry, cant help
all in all, we do need serial ports. even for setting up/maintaining third party devices. i just wished all devices would have tcpip, then i'd be a lot happier
It can be accessed from the Master Comm Settings dialog and then the window showing all the ip addresses you've used in the past has a Listen button on it.
so forget all that stuff i said about scanport. just get the current (as of this date) netlinx studio.
doh... that'll teach me not to look around at new features
