Massio MPK-108 Backlight Button
Hi,
I need advice on how to turn on and off the LEDs responsible for the key backlight in Massio MPK-108, I did not find such information in the device manual. There is only a hint in the manual regarding the LEDs at the knob.
I'm going to use the button_event command but I don't know what command is responsible for these leds from the button backlight.
I see it like this:
button_event [dvKeypad, 1]
push:
{send_commadn "LED 1 ON; LED 2 OFF; LED 3 OFF; LED 4 OFF"
For the volume knob I have it done like this using scaling:
button_event [dvKeypad, 13]
push:
LEDLevel = ((LEDmax-LEDmin) / (Max_Volume-Min_Volume (DecimalVolumeData2-Min_Volume) + LEDmin)
send_level dvKeypad, 1, LEDLevel
    Button numbering is on pdf page 16:
    https://www.amx.com/en/site_elements/instruction-manual-massio-controlpads-and-keypads
    Port number is shown as 28 on pdf page 34.
    Did you try just turning that channel on?
    ON[dvKeypad,1];
  • Thanks for the advice, command ON[dvKeypad,1]; works.
  • Apart from the up and down channels for the volume when rotating the knob, the volume knob also generates a level (2) and the volume bargraph can accept a level (1).
    DEVLEV dlMKPBar  = {dvMKP108,1}
    DEVLEV dlMKPKnob = {dvMKP108,2}
    LEVEL_EVENT [dlMKPKnob]
        SEND_STRING 0, "'MKP108 Knob: ', ITOA(LEVEL.VALUE)"
        SEND_LEVEL dlMKPBar, LEVEL.VALUE
    In the level event you can send the level.value to an (audio) device, scaling it as necessary, the level itself is always 0 to 255 and can't be changed iirc.
  • Hi,
    Thanks for that information, as You mentioned I used the knob rotation to light up the LED bargraph.
    I do this using some scaling function.
