Password reset?
Today I changed the administrator password on a brand new NX-2200 from the default to a customer specific one and got locked out... I probably made a typo, although I could swear I didn't...
Don't think I ever did that before in 20 years of AMX, but here you go.
I soon realised that login is required on the RS232 program port as default, so I couldn't use the 'resetadminpassword' option.
Something I read to hold down the 'ID' button, while powering on the controller, also did nothing.
Is there any way to recover from this? I know this has been difficult/impossible in the past, but not being able to recover from something so basic seems weird.
I'll answer this for future reference:
Got this answer from @Marc Scheibein :
the „10 seconds on boot“ are a little tricky in timing. If I had to do, it also took me sometimes 2 or 3 attempts… Additionally, the LED blink patterns have changed a little…. I tested it, not against the blink pattern, but by timing J. - Remove power - Push and hold the ID button - Connect power - I counted to 15, then release ID The NX now should reboot few seconds later, and should come back with factory reset (DHCP, empty program, and also default admin password)I tested this on my own NX-1200 and the timing IS critical, but it worked fine.
When I performed the 'reset to factory defaults with the ID button' on the NX-2200 from the first post, it was way, way harder then doing this on my own NX-1200. After 5 tries I still was locked out (wrong credentials).
So thinking I probably held the ID button too long at least once, then the NX got set back to it's factory default firmware (in my annoyed state I forgot to check....). Maybe the procedure was different in this version. So I upgraded the firmware back to the most recent version. After a reboot I was still locked out (expected). So I performed the 'reset to factory defaults with the ID button' again, and it worked the first time...
So it could be just dumb luck, could actually be the firmware version, I don't know. Just mentioning it here in case someone else gets stuck.
