Potentially very simple DEVCHAN question
Sort of a beginner here, thrown into the thick of things. I have what I think is probably a simple question- I want to reference a DEVCHAN in an IF statement. Specifically, something along the lines of IF ([DEVCHAN == ON]) however that returns a syntax error. How do I write that properly? Can I use ON in that manner, do I not need the == and just a comma instead?
Thanks in advance!
try
if([DEVCHAN]){}
That's it- I don't need to add a "modifier" of any kind? ON/==/ or assign a value for ON?
Your suggestion compiles fine I am just not sure how it would work as I haven't specified what I want from the DEVCHAN?
Thanks!
In NetLinx everything that is not '0' is considered true, '0' is false:
If (variable) { //runs when variable is not zero }0 is false and in this case false is off.... and true would be on
Thanks all! That got me what I needed. Appreciate the fast responses!
