HDTV Modulated using mini RGBHV CABLE
Will this work in a retro fit application? No RG6 pulled to TV location. Can't seem to get a consensus from a couple of RF engineers I spoke with.
  • John NagyJohn Nagy Posts: 1,756
    A great solution for long distance HDMI via literally any 2 conductors is from CALRAD. It really works. Only downside is lag - if the destination uses audio from another path, it will not lipsynch. If you take the audio with the HDMI at the receiver, it's great. https://www.calrad.com/calrad-2wire
  • banobano Posts: 175
    Thanks John! Great solution piece for legacy wiring! You da man!
    I forgot to mention you can put your RS232 and IR through those same 2 wires with this device, up to and beyond 1,000 feet. Reuse the coax from cable or sats too. (Not a paid review!)
