Home AMX Networked AV (SVSI) Products
Is it possible to receive an audio signal from N4321 Transceiver on N2422A Decoder using SVSI?
Hello
I have 2 devices.
NMX-ATC-N4321 Audio Transceiver and
NMX-DEC-N2422A Decoder in SVSI network
Is it possible to get an audio signal from phoenix audio out of N2422A Decoder?
In other words. Can I receive audio signal from N4321 Transceiver on N2422A Decoder using SVSI?
Thank you,
Alex
Answers
  • Please see the attached diagram.
  • emdx71emdx71 Posts: 51
    yes I believe its possible, the 4321 has an audio in stream and an audio out stream, you'd need to un check the box that says something like audio follows video on the 2422 and then set the multicast ip or stream number on the audio side to the channel number the 4321 is putting out. Also on the 2422 you'll need to set the audio output type to analog.
  • Yes - the SVSI Audio streams across all product families (N1000, N2000, N3000, N4000) are the compatible with each other. Video streams, not so much. On the N2400 you must disable AES67 for the SVSI Audio to be enabled.
