Home AMX Networked AV (SVSI) Products
VGA Auto Adjust on N2300
Hey AMXers!
I've got a (hopefully) quick question on N2300. We have a client who has a VGA only device permanently connected to a N2300 encoder, and it is luck of the draw whether the VGA auto adjust is going to work correctly to have the image appropriately centered on the screen. Often times the image will be shifted left or right. The only reliable way we've found to get it to recenter is to switch to the HDMI input of the encoder, and then back to VGA. This works, but takes a long time to do (8-10 seconds of no video as each of the two switches happen). Is there an API command of some kind I can send to ask the encoder to run the auto adjust as needed?
Thank you,
Brooks
