enable audit security from telnet?
emdx71
Greetings,
I'm looking to enable logging to a syslog server audit server, I'm able to set the audit server via telnet without issue but I've found to have the NX controller actually start sending the logs, you need to hit its webpage, go into security and check the box for audit log.
Is there a way to do this through a telnet session or somehow through code without having to hit the controller webpage?
haven't used it yet, but may to be enabled/disabled by telnet to the NX, call SETUP SECURITY, option 1 (set system security options), and again option 1 (Audit Log).
See also NX webconsole manual, page 121 and up.
https://www.amx.com/en/site_elements/webconsole-programming-guide-nx-series-controllers-enova-dgx-enova-dvx-massio
This was exactly it. Thanks much Marc
