Home AMX Technical Discussion
AMX Varia & SIP
Whilst I know that the VARIA panels don't have SIP, is there anything stopping me from running the TP Control app on them in Kiosk mode - I'm already running TP Control on the site and the customer wants to buy the VARIA panels but we need SIP for the intercoms.
Is that possible?
if it was possible, the resolution is the only issue I can see being a problem - finding a template that would work. I need SIP to work under our control not as a separate App...
Can of teh Harman Mods involved in Varia development give me some pointers please?
  • Best would be to send a feature request directly to Tech Support or your Sales Rep.
    From technicel point of view, as in Android itself SIP got removed (afaik first the implemented SIP dialer longer ago, and from Android12 the complete SIP stack), SIP may have to be implemented into the TP5 app natively.
    Just my $0.02 thoughts
  • Hi Marc
    I did that through the UK support. But there is no indication if it will be done or when.
    So I thought this would be a more immediate solution and no reason why it wouldn't work as I'm already using BYOD on this site anyway....
    @HARMAN_Rob @HARMAN_icraigie @HARMAN_Chris
    Can this be done???(using TPControl app that is??)
  • Any chance of an answer Harman Mods? Usually someone will bother to answer.
    @HARMAN_Rob
    @HARMAN_Chris
    @HARMAN_icraigie
    @duncanbe - The current product does not support SIP out of the box. One could load TPControl to the device, but at this time there is not a published method for booting the device to a 3rd party application. We expect this capability in the near term with a stated feature release date of Q4 CY23.
    @HARMAN_Chris thanks for the reply. That's great thank you.
    Is there any feature release date for SIP?
  • LaurentLaurent Posts: 2
    @HARMAN_Chris
    Hello,
    Any news about SIP support ?
    With TPControl or an Anrtoid SIP Client like GS Wave or Linephone
    Regards, Laurent
    Product manager @HARMAN_Rob is aware of the feature request and has indicated in prior communications that this is something that has been prioritized within the project but has not publicly commented on a possible release date. As you can imagine, we are not at liberty to share information on unannounced product features. All I can say is that we are aware of the need and are working through a process to include features like this into the product via software enhancements that come through normal product evolution cycles.
  • ValhalaValhala Posts: 2
    Any good news from march about SIP integration? We have 9pcs Varia panels in one building and we have to solve communication and 2N integration ASAP. Thank you, regards Tomas
  • I have the same issue and now the Modero are being discontinued, I'm a bit screwed.
    If you have iOS devices on your system, and are using the BYOD licences from TPC - you can load their app and run it inside the G5 app. JUst trigger the app when the Varia comes online. You'll just have two device numbers for each panel
  • sylvesterbasylvesterba Posts: 1
    I am also stumped by the lack of SIP integration with a disappointed client regretting updating from Modero.
    It seems crazy that Varia is less flexible than Modero considering the market that AMX products are aimed at.
    Please advise so to when can we expect a viable solution?
  • Duncan EllisDuncan Ellis Posts: 172
    If your are using TP control BYOD on your project you can side load it and use it as an App. I've done that. I'ts ot ideal, but it does work. You end up with two device numbers per device
