Compiler weirdness
Anyone, please look at the below code. Its a fragment of a bigger project which I have studied and studied but find no reason for the syntax error indicated below.
DEFINE_FUNCTION INITIALIZE_STRUCTURES()
STACK_VAR INTEGER i;
STACK_VAR INTEGER i2;
i2 = 0; //  <<<<<<<<<< IF I REMOVE OR COMMENT THIS POINTLESS LINE OUT, I GET A SYNTAX ERROR ??
TDIMMERS[1].ID = DIMMER_LAMP_1;
TDIMMERS[2].ID = DIMMER_LAMP_2;  // <<< SYNTAX ERROR INDICATED FOR THIS LINE HERE ??
TDIMMERS[3].ID = DIMMER_LAMP_3;
TDIMMERS[4].ID = DIMMER_LAMP_4;
TDIMMERS[5].ID = DIMMER_5;
    edited November 2023
    Remove the semicolon after the stack variable declarations
    DEFINE_TYPE
    STRUCTURE lightingDevices
        INTEGER ID
        CHAR Name[30]
    DEFINE_CONSTANT
    VOLATILE INTEGER nMaxLightingDimmers = 30;
    VOLATILE INTEGER DIMMER_LAMP_1  = 1;
    VOLATILE INTEGER DIMMER_LAMP_2  = 2;
    VOLATILE INTEGER DIMMER_LAMP_3  = 3;
    VOLATILE INTEGER DIMMER_LAMP_4  = 4;
    VOLATILE INTEGER DIMMER_LAMP_5  = 5;
    DEFINE_VARIABLE
    lightingDevices TDIMMERS[nMaxLightingDimmers]
        STACK_VAR INTEGER i
        TDIMMERS[5].ID = DIMMER_LAMP_5;
  • KielLKielL Posts: 37
    Syntax errors are usually pretty hard to track down because the compiler usually flags the wrong line. I'd try looking somewhere above that function to see if anything looks unterminated. I tried duplicating your code and this file compiles without error:
    PROGRAM_NAME='Compiler Main'
    DEFINE_CONSTANT
    DIMMER_LAMP_1 = 1
    DIMMER_LAMP_2 = 2
    DIMMER_LAMP_3 = 3
    DIMMER_LAMP_4 = 4
    DIMMER_LAMP_5 = 5
    DEFINE_TYPE
    STRUCTURE TDIMMER
        INTEGER ID
    DEFINE_VARIABLE
    VOLATILE TDIMMER TDIMMERS[5]
    DEFINE_FUNCTION InitializeStructures ()
        STACK_VAR INTEGER i
    DEFINE_START
    InitializeStructures()
  • Semicolons are allowed at function stack_vars....
    define_function CHAR[20] CreateFaderString(integer nModuleID, integer nParamType, integer nParam1, integer nParam2)
        stack_var char sFinalString[20];    // der finale String mit Anfangsbytes, checksumme und Daten
        stack_var integer nChksumValue;     // Summe der 2 Startbytes und der Databytes
        stack_var char sChkSumBytes[2];     // Summe auf 2 Bytes umgerechnet
        stack_var char sData[8];                    // Datenbytes
        stack_var integer nX;                           // Zähler FOR() Schleife
        // Die Control Daten zusamensetzen, gleich ins passende Format
        sData = "IntegerToBytes(nModuleID,1), IntegerToBytes(nParamType,1), IntegerToBytes(nParam1,1), IntegerToBytes(nParam2,1)";
    //further stuff to follow
    works fine, just wrote this an hour ago....
    Also tried again with the original code, compiles well for me:
    define_type
    struct dimmers
    integer id
    define_constant
    integer DIMMER_LAMP_1 = 1;
    integer DIMMER_LAMP_2 = 2;
    integer DIMMER_LAMP_3 = 3;
    integer DIMMER_LAMP_4 = 4;
    integer DIMMER_5 = 5;
    define_variable
    dimmers TDIMMERS[5];
    By whatever reason, sometimes invisible, not allowed characters find the way into the sourcecode file, and the compiler gets in trouble with that, reporting a syntax error that "visibly doesn't exist". Finding them is hard, sometimes only possible by a hex editor....
    I also can remember that there are also some combinations of code elements that the compiler interprets as syntax errors, though by language are ok.
