Home AMX Control Products
snapiro.jar
When I compile the jar package generated through eclipse using Nelinxstudio, I am prompted that the snapiro. jar package is missing. Who has this file? Could you please send a connection so I can download it!
  • you mean snapirouter.jar or snapirouter2.jar ?
    these files should be located at C:\Program Files (x86)\Common Files\AMXShare\Duet\bundle
    If you check in Studio Help - About NetLinx Studio, what Cafe Duet Runtime Environment version is shown?
  • ychych Posts: 47
    ---------- Starting NetLinx Compile - Version[2.5.2.420] [11-24-2023 10:01:32] ----------
    G:\java\KeDaMcuUpdate\KeDaupdate.axi
    ERROR: (0): L20206: File [snapiro.jar] could not be found
    G:\java\KeDaMcuUpdate\KeDaupdate.axi - 1 error(s), 0 warning(s)
    Compiled Code takes 1245377 bytes of memory -- Token and Variable Count is 6353 (Maximum is 200000)
    NetLinx Compile Complete [11-24-2023 10:01:34]
    NETLINXSTUDIO:4.4.1914
    com.amx.duetdesign_3.1.0.jar
  • ychych Posts: 47
    I have installed the latest software for Cafe Duet Runtime Environment on my computer, but I cannot find it in the application!
  • that seems to be a custom jar file. Jar Files will not automatically transferred to the controller if they are not part of a Duet driver.
    You may have to load it manually to the controller as a "non system file" (File Transfer -> Add -> Individual Files -> send Non-System File). If this will not solve it, unfortunately I don't have any more idea, sorry.
  • The manifest is corrupted - there is a line length rule that is being broken. The latest version of the plugin properly checks for this. https://proforums.harman.com/amx/discussion/138025/cafe-duet-plugin#latest
  • ychych Posts: 47
    Thank you for your guidance. I have installed the latest plugin and have resolved this issue. Thank you very much!
