CheckSum8 Modulo 256
Hi,
I need advice on how to implement CheckSum8 Modulo 256 in Netlinx Studio.
In past, I used that function to calculate checksum:
DEFINE_FUNCTION CHAR BXORcheckSum(CHAR sBytes[])
stack_var char this_sum
STACK_VAR INTEGER nX
this_sum = $00
FOR(nX=2;nX<=5;nX++)
this_sum = this_sum BXOR sBytes[nX]
SEND_STRING 0, ("'Checksum PRocess Result: ',this_sum")
RETURN this_sum
That function worked correctly, but now I control different TVs, and now works only with checksum calculation using CheckSum8 Modulo 256
https://www.scadacore.com/tools/programming-calculators/online-checksum-calculator/
  • Marc ScheibeinMarc Scheibein Posts: 973
    edited March 2024
    It's pretty simple... create sum of all bytes the checksum has to be calculated over, and then do a MOD 256 to that sum, to get just the lower 8bits of the sum
    // calculates the MOD256 value of a String
    // char sString: the string to calculate the checksum of
    // returns a char with the chksum value
    define_function char chkSumMod256(char sString[])
        stack_var integer nSum;
        stack_var char cChkSumByte;
        stack_var nX;
        for(nX=1;nx<=length_array(sString),nX++)
            nSum = nSum + sString[nX];
        cChkSumByte = type_cast(nSum % 256); // MODulo; 256dec / $100 hex; typecasting required as converting  integer (16bit) to char(8bit)
        return cChkSumByte;
  • Hi,
    Thanks for the advice, but unfortunately this code doesn't work entirely correctly.
    I want to send a string to increase and decrease the volume like that: $AA$12$01$01$0F$(CRC)
    Where I have to calculate CRC every time that's why I need this function.
    And now when I put this string into the CRC calculator from this website:
    in this form: 1201010F, I get CRC = 23 and this is how it should be(result in attachment).
    Whereas with your code I get 12
  • hm, I added a little code around, the function is unchanged, working as expected...
    rename the txt file to axs.
    The only difference I see just now is that in the first code I had a comma in the FOR() parameters instead of a semicolon. But this gives a syntax error when compiling, so should not have an effect to the result.
  • I couldn't see what would be wrong with the code either, so I ran it and it produces the right checksum. when I put in:
    "$12,$01,$01,$0F"
    23 comes out as the checksum, as expected. So don't know what is different on your side
  • Hi.
    Yes, the function works correctly, it's my fault in implementing it in my code.
    Thanks, Marc Scheibein for help.
