Home AMX User Forum Muse Automator
Touch Panel Apps
Can anyone provide guidance on implementing control apps with Muse?
  • what kind of control apps you mean?
  • EuroCatEuroCat Posts: 12
    Such as TCControl for Android.
  • archliveceharchliveceh Posts: 9
    edited October 2024
    @EuroCat I am not sure about TCControl but have done this with windows and iPad using AMX TPControl app. For android TPControl application need a android tab which certify the TC Control requirement. Next you will need a license from TP Control. App can be designed in TP designer from AMX. Then it can be transferred to android device using TP Transfer Tool.
    Regarding MUSE what you want to use Muse Automator or Muse Mojo VS Code plugin?
  • The TPControl Apps should work as expected with Muse, as they act like a normal ICSP panel.
    Not supported yet is BOYD with Muse. I got told this is currently not in development, as Touchpanelcontrol at the moment focuses on reworking the TPC apps.
    Thank you for the replies and information. It was helpful to understand what the current status is.
    I am sorry about the misleading typo. I meant TPControl.
  • Today came a technote about TPControl Apps having problems with Muse:
    https://help.harmanpro.com/muse-with-tpc-apps
    As TPC-TPI-PRO is not affected...
    By experience, for Windows based TPC, you may install the TPI-PRO app, and by a normal TPC-WIN license, TPI-PRO gets limited to the functions of normal TPC-WIN. But keep in mind that the TPI-PRO version of TPC is designed to run on a regular PC, and so uses higher resources.
  • Duncan EllisDuncan Ellis Posts: 172
    edited November 2024
    I think the issue is authentication for Muse with TPC - i.e license validation.
    We've been working with TPC to get SIP working again on the iOS version as they had to use a new build of Linphone, which wasn't straightforward. They used our office as their test base. Now works spot on.
    I believe Muse is a different matter for BYOD, but normal licenses should be fine - with the exception of the error above
