Barco G62 Series Duet Module
I need to control a Barco G62 Series projector. I have looked in developer.amx.com but did not find a reference to the model.
Does anyone know if Barco are consistent with the RS-232 protocol over various models so I could possibly select another Duet Module?
Willie
by the datasheet, this projector could be controlled by network with the PJLink protocol.
https://developer.amx.com/#!/searchresult?Manufacturer=JBMIA&Model=PJLink
Thank you Marc.
The Barco projector replaced an older projector, so the control infrastructure is existing. IP control would require running a network cable which we want to avoid.
I understand this
Well, as most control is done by IP now, and with PJLink available, I don't think that there is any matching module available for this projector generation....
But the serial protocol is ASCII based:
https://www.projectorcentral.com/pdf/projector_manual_11790.pdf
Appendix B.1
So for a basic control, it shouldn't be too difficult.
