Home Scripting Languages
Running into problem using the "Export Script Function"
I'm trying to use the muse "Export Script Functionality" as described in the MUSE Programming guide, Below is my JSON:
"$schema": "https://developer.amx.com/schema/amx-mojo-program-1.0.json",
".metadata" : {
"id": "Muse-BiAmp-IP-Interface",
"name": "Muse-BiAmp-IP-Interface",
"description": "description",
"disabled": false,
"provider": "python",
"scope": "",
"script": "BiAmpIPInterface.py",
"envvars": {}
"noArgument":{
".kind": "command",
".metadata": {
"method":"noArgument"
"sendCommand":{
".kind": "command",
".arguments": {
"command":{
".type": "string"
".metadata": {
"method":"sendCommand"
The Muse controller creates a device, and when i pull the descriptor files for that device, everything looks correct, but if I try to invoke those commands via the MUSE cli, i get the following error:
Error executing command: An exception was raised by the Python Proxy. Return Message: Traceback (most recent call last):
File "/mnt/data/mojo/mojo/pylib/py4j/java_gateway.py", line 2467, in _call_proxy
return_value = getattr(self.pool[obj_id], method)(*params)
File "/mnt/data/mojo/mojo/pylib/mojo.py", line 1139, in call
f = self.scope[method]
TypeError: 'NoneType' object is not subscriptable
As far as i can tell, It does not even try to hit my script. I'm at a loss since as far as i can tell I'm matching what the programming guide says. Am I missing something somewhere?
