Home AMX Technical Discussion
How do u remove an entry from a structure
johnbonz1johnbonz1 Posts: 45
edited May 16 in AMX Technical Discussion
So I have a structure, and there are 19 entries. I want to delete 2 of them, and I issues a command:
sCalendar_Anniversary[i] = sClearCalAnniversary;
this will make all the columns within the structure as zero. But these 2 entires are still part of my 19 entries. Is there a command like in java to delete the entries instead of me just zeroing out the columns within the structure?
  • Marc ScheibeinMarc Scheibein Posts: 961
    In NetLinx, a buffer or array length once defined is always reserved in memory.
    So in your case, the structure array, once defined with a length of 19, has reserved this memory forever.
    volatile _myStruct myStructArray[19] // will have 19 elements of the structure in memory, this is fix reserved
    What you can do is to define how much elements of that array should be "operational" by the string and array operators.
    set_length_array(myStructArray, 17) // the operative length of the array is now 17
    The content of the structure elements 18 and 19 now is still present in memory, but no longer available for any array or string instructions.
    myLengthOfArray = length_array(myStructArray) // the currently operational length is reported 17
    myMemoryLengthOfArray = max_length_array(myStructArray) // reports the length that was created im memory
    Direct access into the memory cells of array elements 18 and 19 is still possible
    result = myArrayStruct[19].structElementData // reading
    myArrayStruct[19].structElementData = 'hello' // writing
    But though writing data into cells of myArrayStruct[19], the length_array() is still 17
    To make them available again for string and array operator, the operative length must be set again to 19
  • johnbonz1johnbonz1 Posts: 45
    Thanks, that seems to work. It is a convulated way to remove a array entry. In java all u do is do arry.remove(17) but it seems to work, so thanks again, just need to be aware of how many elements will be added to structure as it is dynamic. so every time I want to add an element I have to do this:
    1) add one to the array length: if prior length was 17, then new length will be 18
    set_length_array(sCalendar_Anniversary, 18);
    2) then set the array structure(18) to new value(s) -- in sTmpCalAnniversary
    sCalendar_Anniversary[18] = sTmpCalAnniversary;
  • John NagyJohn Nagy Posts: 1,754
    edited May 17
    It would seem simpler to maintain an "active array length" variable, set it appropriately, then when you access the fixed size array, only read the number that are active. Effectively, make a virtual active array size stored in a larger reserved space. Let any surplus elements be ignored. (But as I don't know your application, this may not work for you.)
    But as you suggest filling the unused section of the array with zeros... instead of sizing gymnastics or calculating when/if/how to fill unused elements, when your data changes, first do a simple clear/all-fill the array with zeros (or choose a "not valid" placeholder), then load your valid data over that.
    So many ways to accomplish the same thing. Save cycles, save memory, or save coding time... your choice. Which do you have the most of to spare, and at what cost?
