Home Muse Automator
Muse Automator - Protocol 3000
I am developing my first AMX Muse Automator project.
I need to operate a Kramer FC-7P relay unit over IP. Using Hercules, I can close a relay with '##RELAY-STATE 1,1'. I can open a relay with '##RELAY-STATE 1,1' and it works.
The above strings are not working in Muse Automator. I have tried using only 1 hash sign.
I would appreciate any thoughts on this.
  • EuroCatEuroCat Posts: 12
    I should add that I did have a behind each string.
  • Marc ScheibeinMarc Scheibein Posts: 973
    The basic instruction node might be a "change", with a payload as JSON format
    Where the \r represents the carriage return 0x0D (linefeed is a \n, crlf is \r\n)
    The IP connection itself might be a "tcp request" (use your IP settings)
    The TCP request node does a Client connect, then sending the payload, and delivers a reply from the connection.
    In the setup of the screenshot, the connection is kept open.
