Home Scripting Languages
HControl error on SVSI Decoder Serial port
ernestmusseriiiernestmusseriii Posts: 22
edited July 16 in Scripting Languages
I get this error when the system recieves a serial repsonse from a MAXXHUB display. This happens with or without a callback function inside the ".response.listen" block. This happens with all the decoders.
Am I doing something wrong here?
*******************Error***************************************
07/16/2025-10:34:34.793 | ERROR | pool-2-thread-175 | HControlDriverClientListener | 31 - com.amx.mojo.hcontrol - 1.14.26 | Failed to decode argument data from
07/16/2025-10:34:34.818 | INFO | pool-18-thread-1 | Program-AVControl | 41 - com.amx.mojo.thing - 1.14.26 | Data-Event: LOBBY-TV-1:
07/16/2025-10:34:40.010 | ERROR | pool-2-thread-175 | HControlDriverClientListener | 31 - com.amx.mojo.hcontrol - 1.14.26 | Failed to decode argument data from :01S:001
07/16/2025-10:34:40.014 | INFO | pool-18-thread-1 | Program-AVControl | 41 - com.amx.mojo.thing - 1.14.26 | Data-Event: LOBBY-TV-1: :01S:001
************************Code*******************************
dvLobbyDisp1.online(function(){
log.info(<!== Lobby TV 1 ONLINE ==!>);
dvDispIsOnline['LOBBY-TV-1-DEC'] = true;
        dvLobbyDisp1.decoder.serial.response.listen(function(event) {
            fnDataEvent("LOBBY-TV-1: "+String(event.arguments.data))
    dvLobbyDisp1.offline(function(){
        log.info(`<!== Lobby TV 1 OFFLINE ==!>`);
        dvDispIsOnline['LOBBY-TV-1-DEC'] = false;
  • Marc ScheibeinMarc Scheibein Posts: 972
    This sample shows in Python how to handle serial data.
    https://help.harmanpro.com/controlling-muse-serial-ports-with-python-code
    You may have to decode your incoming data first, before using.
    Thank you for the response. This error does not come from the string handler though. I can comment out the code inside response.listen, and I still get the error. I'm trying to determine if this is related to SVSI or if this is specific to the Maxxhub display protocol sending back a character the underlying code doesn't like.
