Home AMX Technical Discussion
concatenate issue
johnbonz1johnbonz1 Posts: 47
edited October 26 in AMX Technical Discussion
question why does this not concatenate properly?
I have a string
part1Str LEN = 71
part1Str = Authorization: Digest username=admin,realm=Avigilon-112008310210,nonce=
part2Str LEN = 46
part2Str = DNTq7Z1hfR1UxPrdYS3l92ljZ8clQfHsfmWP295c0b0000
part3Str LEN = 35
part3Str = ,uri=/onvif/device_service,gop=auth
then I concatenate each var above to final string variable called finalStr
finalStr LEN = 71
finalStr = Authorization: Digest username=admin,realm=Avigilon-112008310210,nonce=
finalStr LEN = 117
finalStr = Authorization: Digest username=admin,realm=Avigilon-112008310210,nonce=DNTq7Z1hfR1UxPrdYS3l92ljZ8clQ
finalStr LEN = 152
See the string from
get truncated when I concatenatre to finalSTR-- DNTq7Z1hfR1UxPrdYS3l92ljZ8clQ
why is that?
  • What language we are talking about? This doesn't look NetLinx language
  • johnbonz1johnbonz1 Posts: 47
    edited October 27
    The language is NetLinx Studio
    I will beak it out better
    local_var char part1Str[128];char part2Str[128];char part3Str[128]; char finalStr[1024];
    part1Str LEN = 65
    part2Str = nonce=6xeTM9l9I78GRrXUgRnkjDx70nFMLv6hQzYS2Tdb020000
    part2Str LEN = 52
    part3Str LEN = 35
    Now I concatenate variables part1Str,nonceStr,part3Str into var finalStr
    finalStr = "part1Str,nonceStr,part3Str";
    finalStr LEN = 152
    result is below - note how after 100 bytes its cut off but when I do itoa(length_string(finalStr) value is 152
    finalStr = Authorization: Digest username=admin,realm=Avigilon-112008310210,nonce=6xeTM9l9I78GRrXUgRnkjDx70nFML
    what I expected is this: 152 bytes
    Authorization: Digest username=admin,realm=Avigilon-112008310210,nonce=6xeTM9l9I78GRrXUgRnkjDx70nFMLv6hQzYS2Tdb020000,uri=/onvif/device_service,gop=auth
  • When checking in the debugger, as long as the total length is 152, everything is ok.
    If you verify this by Diagnostics or send_string 0, the string will be truncated in the output. Here you have to split the string into parts, you may use the attached function
