Setting all values in an INTEGER array
On the bottom of page 134 of the AMX Programmer book, it seems to indicate that you can set multiple values of an INTEGER array in one line using string syntax. However, in my little sample program below:
DEFINE_VARIABLE
INTEGER array[10]
DEFINE_START
array = "12,13,4"
I get an Dimension mismatch: [1] vs. [0] error on the DEFINE_START line. If I switch the array to a CHAR array it works (of course). Am I missing something obvious?
Patrick Clemins
TECHteriors LLC
Milwaukee, WI
DEFINE_VARIABLE
INTEGER array[10]
DEFINE_START
array = "12,13,4"
Patrick Clemins
TECHteriors LLC
Milwaukee, WI
INTEGER nARRAY[3] = {12,13,4}
or an "unsized array"
INTEGER nARRAY[] = {12,15,65,23,66,43,99}
Even if you declare it a size of 10, you can still only declare the first three.
INTEGER nARRAY[10] = {12,13,4} would look like this in the diagnostics view
In this case this will not work because a string operation is used on an Integer array.....
If necessary to do this in DEFINE_START, every single element of the array must be filled separately....
OR
if the values are <256, use the CHAR type array (I use this "workaround" in several places
Welcome aboard Patrick.
If your want to initialize the integer array values in Define_Start, the correct method is as follows as explained correctly by Marc. Here is an example.
I usually use the method Jerimiah suggested in the Define_Variable section.
I don't think I can define the values for the array in DEFINE_VARIABLES because the array is actually a data member of an array of structures, so my code in DEFINE_START really currently looks like:
znZONE[1].array[1] = 1
znZONE[1].array[2] = 2
I left that out to simplify the original question... Marc gave me the answer I was looking for... I can't do that. <256 is fine, and I kinda wanted to hear that others did the CHAR array workaround before I did.
Thanks for the input!
Patrick Clemins
TECHteriors, LLC
